damn transmission
Old Aug 18, 2007 | 06:01 PM
mike25's Avatar
damn transmission
ok well im not 100% sure what the problem is so maybe you all can help..everytime i put my car into reverse (standard getrag tranny-2.4)....my trans grinds a slight bit.....now i know your all probably thinking o well the clutch aint all the way to the floor.....and yes it is....as far as it will go to the floor....and the **** still grinds....sometimes its bad...sometimes its slight...and sometimes it just doesnt do it at all...for the most part it grinds bad for like a split second....it does it just as im sliding in to reverse and then after that its over.....does anyone know what the hell is wrong?
Old Aug 18, 2007 | 06:09 PM
OrngBalt's Avatar
bring it to the dealer if you are still under warranty
Old Aug 18, 2007 | 07:18 PM
mike25's Avatar
i know that but i was wondering what it might be
Old Aug 18, 2007 | 07:29 PM
Kritter's Avatar
Ther were some people who were having issues similiar to this, and it turned out to be a roll pin I believe, that needed replacing. If I'm wrong someone let me know.
Old Aug 18, 2007 | 07:30 PM
mike25's Avatar
i dont suppose i could demand a new transmission....due to the damage that this is causing....because it does this ALOT
Old Aug 18, 2007 | 07:36 PM
DrPuttsSS/SC's Avatar
Don't want to sound like the dealer here but there may not be anything wrong. I've had lots of cars that gave a little grind when I went into reverse. Maybe just a half second, not a long grind. It's just because you are reversing some of the parts in the tranny.
I've never had problems with cars that ground a little every time.
Sometimes it seems to help if you tap the gas in neutral before pushing in the clutch and pulling the shifter back. Gets the gears more in sync.
If it grinds for a while and doesn't want to go in you do have a problem. But if it just makes a little noise as it slides in you are probably ok.
Take it back to the dealer since it's still under warranty.
Old Aug 18, 2007 | 08:55 PM
mike25's Avatar
its not alittle grind its a moderately loud grind...and sometimes the shifter wont even go in...it shouldnt do this as it has never done this before
Old Aug 18, 2007 | 09:27 PM
Yeah, take it in! Sounds like somethin's wrong.
Old Aug 18, 2007 | 09:41 PM
mike25's Avatar
thats what i thought....i mean ive never had a problem out of it for the 2 years ive had it...and all of a sudden its doing this.....i mean i drive spiritedly...and my trans was a learner...its had its share of grinds....but it still shouldnt be doing this
Old Aug 18, 2007 | 10:26 PM
g5mike's Avatar
Good luck with that mike,keep us updated.
Old Aug 19, 2007 | 10:06 PM
mike25's Avatar
i sure will...lol thanks for the encouragement
Old Aug 19, 2007 | 10:09 PM
R&C_rallySS's Avatar
Has anything to do with the clutch and flywheel being after market. Just guessing at this point. I know with the B&M short throw you have to be careful how tight you screw the knob on. If its to tight reverse will grind or not work at all.
Old Aug 20, 2007 | 10:23 AM
mike25's Avatar
but thats the problem....i have no aftermarket clutch/flywheel...or a shortthrow...lol you might have confused my future mods with what is done
Old Aug 20, 2007 | 10:29 AM
Witt's Avatar
I know the F35 tranny has reverse synchronized, is the one in the 2.4 syncro'ed as well?
Old Aug 20, 2007 | 10:54 AM
mike25's Avatar
im not sure...maybe someone else would know...its a standard tranny...so i would doubt it
Old Aug 20, 2007 | 11:00 AM
WSFrazier's Avatar
Mine does this too on my F35. If I put the car in 1st then straight to R it works fine.
Old Aug 20, 2007 | 08:39 PM
Mimmsey's Avatar
mine does this too, I am concearned because my reverse lights stopped working in addition to this.....https://www.cobaltss.net/forums/general-cobalt-68/reverse-lights-out-%2Ahelp%2A-72539/
Old Aug 21, 2007 | 03:44 AM
AngelTiger82's Avatar
My car also grinds when I put it in reverse it doesnt happen all the time but it does happen. I do have a B&M shifter .
Old Aug 21, 2007 | 11:59 AM
Witt's Avatar
I found a couple of sites that state that reverse is synchronized meaning it shouldn't grind when putting it in gear. I would take it in for warranty work and let Chevy deal with it.
Old Aug 22, 2007 | 01:38 PM
mike25's Avatar
car goes in at 9am tom. so wel find out what the problem is
Old Aug 23, 2007 | 08:12 PM
mike25's Avatar
well took it in and the dealer told me that its going to grind...its normal...said the reverse gears arent syncroed so the gears dont mesh perfectly causing it to grnd a slight bit...said its not doing and real damage to the trans because the gear teeth are sliding off of each other causing a slight grinding noise....he said thats mostly likely what the problem is and if it gets alot worse then i should have brought back for more extensive work
RaginChopsuey
Oct 27, 2015 01:27 PM
importkiller
Sep 30, 2015 07:18 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
