DTC 2228 code
Old 05-26-2008, 05:50 PM
Sizzle06's Avatar
DTC 2228 code
Ok well i bought the 0w30 that mobil 1 has and changed my oil this morning,so after i change it i turn the car on and let run for a little bit(so far so good)and then shut it off and washed my car.So after i wash my car i went to start it and as soon as i did the cel came on but the car was running ok.I scanned the code and got a 2228 code=barometric pressure circuit low.So do you think it is just getting used to the oil or it's to thin?I have already double checked everything,any help will be appreciated,thanks.
Old 05-26-2008, 05:58 PM
Sunburst_SS's Avatar
make sure you didn't bump the baro sensor, wires, connector.....that's the sensor by the oil filter cap.
Old 05-26-2008, 05:59 PM
sherm420's Avatar
^^ ya dude that happened to me that fucked my **** up the sensor got disconnected then it thru all diff kinds of codes and fucked my pressure couldnt go over 40 mph luckily i was still under warranty
Old 05-26-2008, 06:07 PM
Coblasts's Avatar
Might of damaged the wire going into the connector with the extension ,or not plugged it back in all the way if you removed it..
Another thing to check is that the pins didnt get bent if you had removed it and put it back.
Old 05-26-2008, 07:17 PM
Sizzle06's Avatar
I forgot to plug it back indamn i feel like a moron,thanks guys.
Old 05-26-2008, 07:18 PM
no problem......happens to everyone at one time or another
turbochargedss2012
09-20-2023 12:17 PM
Sl0wbaltSS
11-21-2018 11:11 PM
ernnyyes
10-02-2015 05:16 PM
Extremespeed
09-29-2015 04:34 AM
DocSvensk
09-27-2015 02:24 PM
Quick Reply: DTC 2228 code
