Electrical problems
Electrical problems
So everything in my interior works. The lights, the driver side mirror adjustment and power locks, but I’ve lost all power to my window on the driver side and the r passenger side window and power locks as well. Also the sunroof. Everything else works. This all started when I had my driver side door open and I was putting shifter cables in. I’ve checked fuses. I’ve put a new motor and switch in and still nothing. Literally everything works but the windows and power locks. I’m not getting any power to my window motor. I used a ohm reader to determine that. I have no idea what it could be. If anyone had any suggestions please let me know. I’ve also tried a test light on the fuse it’s self for the windows and I’ve got nothing. Thanks in advance.
Have you checked both sets of window switches? I'm meaning drivers side and passenger side window/lock switches.
Depending on the year the wiring is a bit different, but both switches are integrated for the lock function, I'm not sure about the window function.
yeah I’ve checked all the window switches. The window switch on the driver side has a burnt spot on the board. I’m also not getting anymore to my window motor. I’ve tested with an ohm meter. Can I jump a wire from another fuse to the window fuse on the fuse box(bcm)
GSMiller
01-17-2008 04:35 PM
