Elusive vacuum leak..Cobalt why you hate me so much???
Old Aug 13, 2015 | 09:31 PM
volsfan92's Avatar
Exclamation Elusive vacuum leak..Cobalt why you hate me so much???
So I replaced my intake gasket thinking that was my vacuum leak but I still have a leak somewhere.. Mechanical boost guage reads 4-5psi less than factory Guage.. If I spray carb cleaner on right side of motor around the injector and manifold the idle screws up I can also hear a whistling nose.. Anybody have tips to find this mystery leak? 05 LSJ
Old Aug 13, 2015 | 10:22 PM
double clutch's Avatar
Did you examine the intake manifold for cracks while you had it off? Did you check the condition of the supercharger gasket?
Old Aug 13, 2015 | 10:34 PM
volsfan92's Avatar
Yea I didnt see any crack on the manifold and the rubber part of sc gasket was good...I have been reading and is it possible its coming from the injector insulator ive already replaced orings
Old Aug 13, 2015 | 10:37 PM
rivaladore's Avatar
Fuel injector insulator
Old Aug 13, 2015 | 10:44 PM
volsfan92's Avatar
Thats what Im guessing hopefully my local dealer has one,,would that cause a vacuum leak?
Old Aug 14, 2015 | 12:00 AM
Does the idle bog down a bit when you spray around the injectors? I had the same exact issue and injecotrs werent sealed.
In my case, my id1000s were pushing past the sleeves so there was space between the oring and sleeve. I solved that by cramming a few oring between the injects and isolators lol
Old Aug 14, 2015 | 12:08 AM
volsfan92's Avatar
Yea it bogs bad and I'm going to try a new insulator first I guess I doubt my local dealer will have one though
turbochargedss2012
Sep 20, 2023 12:17 PM
Sep 30, 2015 07:22 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
RedLined
Sep 9, 2015 09:11 PM
