Engine removal
Old 09-16-2019, 08:14 AM
jdbaugh1's Avatar
I still think dropping the whole cradle out the bottom is the way to go. All you need is 2 floor jacks. The reason I think this is the better option is because you disassemble/assemble the whole engine assembly outside of the car where it is easy to work on. When you go through the top you have to disassemble and reassemble inside the engine bay, remove the hood, wrestle the engine in and out with a cherry picker and have to fight the transmission shaft lining up with the clutch with the engine suspended. Much easier to do out in the open IMO. I think you through-the-toppers are just stubborn
Old 09-16-2019, 02:20 PM
Valasco's Avatar
Absolutely. im putting it back in from the bottom
Old 02-10-2023, 01:03 PM
Gab1910's Avatar
I realize this is Many years old at this point
Originally Posted by coopercharge
disconnect everything and drop the cradle out of the bottom.
GM performance division put out a build book so to speak here is part 1 and 2 showing how to remove the engine.
gmperformancedivision.com
This has got to be the most USELESS POS advice out there. Even if you have a hoist in which to accomplish this it does NOT seperate the engine from transmission. I hate that forum answers like this exist you have nothing useful to say yet still feel the need to say it. Next time I hope you either stay off on the forums or actually contribute. What a dumb answer smh
jdbaugh1
10-17-2018 11:13 AM
Medida
04-09-2015 05:51 PM
bcuree
03-07-2013 09:45 PM
TCarter
How to Guide
52
02-26-2009 06:23 PM
Chambers
07-12-2008 04:37 PM
Quick Reply: Engine removal
