Engine seized
Old Apr 9, 2018 | 04:30 PM
ksmith0769's Avatar
Engine seized
Welp my engine is seized. Pretty sure the oil pump failed. So where should I go next? Attempt a rebuild or search for another motor? Need some input here.
Old Apr 9, 2018 | 04:32 PM
Step one would be to tear down the engine and see what actually failed, then decide what to do from there.
If the oil pump did actually fail, youre probably better off looking for a new engine.
Old Apr 9, 2018 | 04:46 PM
ksmith0769's Avatar
It's been at a shop I haven't had time to look at it with work. I asked them what caused it and they didn't have an answer. Tried to rotate the crankshaft and apparently got nothing. All I can think of is the pump failing because I checked the oil level a few days before it happened and was near full. Why do you say it'd be better? I'm concerned with buying a motor and just inheriting the problems from it as opposed to trying to rebuild
Old Apr 9, 2018 | 05:06 PM
Henry3959's Avatar
What engine?
People have posted the same thing and had a locked up SC.
Old Apr 9, 2018 | 05:29 PM
Because if the engine is actually seized, the crank and rods are likely trash and the block/pistons could have some nasty wear. In this case the engine is not really rebuild able.
Old Apr 9, 2018 | 05:30 PM
Originally Posted by HGT
What engine?
Also this. My buddy's Ion had a seized AC compressor and the motor wouldnt even turn over. Try taking the belt off and then spinning the engine over.
could be the Supercharger, AC or alternator. Technically it could even be the water pump causing it.
Old Apr 9, 2018 | 06:19 PM
ksmith0769's Avatar
What engine?
2.0 SC. I need to get it back from the shop and check there unless they have. Haven't gotten an exact cause yet.
Not too hopeful though.
Old Apr 10, 2018 | 12:51 PM
Johnny Bliss's Avatar
no noise just seize????
typically it would make a huge racket as it was destroying itsself with no oil pressure.
Old Apr 10, 2018 | 01:16 PM
user 72239's Avatar
not necessarily.
Colodudes car just shut off when he was idling and the engine was seized. made no noise
Old Apr 10, 2018 | 01:24 PM
i guess is possible.
Old Apr 11, 2018 | 02:44 PM
colodude18's Avatar
not necessarily.
This. And even though there was no load on my engine when it seized, my built head (which is the only thing transferred to the new LDK engine) was "twisted" by overheating and had to be machined twice to make it fit on the new block.
Old Apr 11, 2018 | 02:50 PM
Aluminum does warp easier than cast iron
Old Apr 11, 2018 | 03:38 PM
user 72239's Avatar
wow I didnt know that. thats nuts
OttawaMark
May 22, 2012 07:53 PM
beerbaron105
Dec 17, 2006 10:27 AM
Blown 4-banger
Oct 12, 2006 04:13 AM
