exhaust leak or knock ?
Old Mar 24, 2014 | 12:46 AM
brenxmac's Avatar
2006 2.2 N/A
I've been hearing a ticking noise coming from the front of the car, possibly the engine, probably an early part of my ZZP exhaust. How can i narrow down what/where this issue is, so i can get rid of this awful noise.
The ticking speeds up as the car accelerates, and even tends to change tone or note when car shifts. Ticking is there from start up. Can't see an obvious header crack-maybe gasket or loose clamp idk.
My midlength to dp is out of warranty too so if that’s the case what are my options.
I’m not even going to entertain the idea that it’s a lifter, I’m not ready to go down that road yet
Thanks
Old Mar 24, 2014 | 12:54 AM
More tjan likely an exhaust leak. Do a leak test. It includes essentially.blowing smoke into the exhaust pipe and seeing where it comes out of
Old Mar 24, 2014 | 11:10 PM
brenxmac's Avatar
Thanks, maybe once the weather gets a little nicer this will be something I look into
Sl0wbaltSS
Nov 21, 2018 11:11 PM
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
tomj77
Oct 4, 2015 11:39 AM
Tupp
Sep 30, 2015 08:18 PM
