Getting a clunking sound after installing 18"
Old Feb 18, 2007 | 08:10 PM
bluebeast's Avatar
I am getting a clunking sound from the front end after installing 18" almost sounds like the axles but I dont know the boots look fine, seems like it might just be the front right. And It is only doing while I am not giving it gas, as long as I am driving it is fine but when I slow down or just let off the gas it starts making the noise.
Somebody help
Old Feb 18, 2007 | 08:16 PM
DC52NV's Avatar
no need to make 3 threads for the same thing. i deleted your other 2 threads.
Old Feb 18, 2007 | 10:13 PM
bluebeast's Avatar
i had put in 3 different sections b/c not all people look at every section
When I jack up the car and turn the wheel nothing happens so i don't know if im not spinning the wheel fast enough or that it has to have load on it
Old Feb 19, 2007 | 09:03 AM
bluebeast's Avatar
Old Feb 19, 2007 | 09:05 AM
rally's Avatar
What size rim and tire are you running?
Are you sure you torqued them onto the vehicle correctly?
Old Feb 19, 2007 | 09:35 AM
bluebeast's Avatar
225/40/18 If I would have tightened them to hard could that cause a clunking though
Old Feb 19, 2007 | 09:37 AM
Doc's Avatar
Doc
how tight did you go..?
100ft/lbs is recommended
D4u2s0t's Avatar
which model car do you have? the "clunking" could be the tires hitting the fenderliner over bumps
Old Feb 19, 2007 | 10:22 AM
bluebeast's Avatar
i have the ls model but it is not while going over bumps just while driving straight
Old Feb 19, 2007 | 10:24 AM
Doc's Avatar
Doc
engine mounts make a similar clunking
check the one on the passenger side of the engine
Old Feb 19, 2007 | 10:32 AM
rally's Avatar
Theres almost no such thing as a straight road with no bumps. No matter what your suspension is working even though you think the road is "straight".
And I suggest getting a torque wrench and torquing the wheels to 100ft. lbs in a star pattern.
Old Feb 19, 2007 | 10:37 AM
06CobaltssOrange's Avatar
hey
check ur fenderliner and torque ur tires to the recommended lbs/trq
Old Feb 19, 2007 | 11:57 AM
bluebeast's Avatar
fixed lug nuts loose needed re tightening after the 25 miles
new wheels new lug nuts
turbochargedss2012
Sep 20, 2023 12:17 PM
biniecki
Oct 25, 2015 02:23 PM
justinchinn
Oct 2, 2015 12:18 PM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
