GM STAGE 2 kit back order Please help! lol
I ordered a GM stage 2 kit two days ago from gm parts direct and they sent me an email saying the item was on national back order and I can cancel if I want. But I don't want to cancel if everywhere else is the same way. I don't know if anyone has herd of this and what should I do. I mean it could be two days or 6 months so I was wondering if anyone has herd about this.
no but i would save your money buy injectors pulley and find someone to tune it...it will be safer have more power and save you a ton of money...the 42lb injectors from gm are like 300 and some dollars and they are basiclly maxed out on a stage 2 kit...i have a 3 inch pulley and needed 60s to run safe....imo the canned tune from gm is **** and the injectors and pulley from gm is way over priced...most on here will agree
warrenty only last so long what about after that...as long as you custom tune it and the a/f ratio are perfect...youll be safer imo....as long as your not throwing a 2.7 on the eaton or anything like that.
i have 110000 miles on my cobalt so im more worried about being safe and knowing im safe then hoping the gm canned tune does the trick which in my case it didn't due to the exhaust the intake the 42lbs were maxed out above 5500 rpms people dont take into account the bolt ons they have on there car..those things lean you out...the best thing is the get an a/f gauge
What most people don't know is the 42 lb/hr injectors that come with the GM stage kits work fine at high pw/idc's. Also, there is no way you maxed the injectors at 5500 rpm on a GM Stage 2 pulley. The only way you could do that is if you were running a much smaller pulley. Hell, my Stage 3 pulley doesnt start over working the injectors until i get up around 7k rpm.
First of all do you know how rich most GM Stage tunes are ?? An intake, and exhaust will not lean you out to the numbers you claim. GM's leanest Stage 2 tune was its 07' version, and that still commanded a 10.8 a/f ratio. There had to be some other issue with your car. It was def. not the GM tune causing you to have those kinds of conditions. I stand by what I say about you not being able to cause your injectors to go static at 5500 rpm on a GM Stage tune with the 77.9mm pulley.
Ya I was trying to keep my warranty. I have an 07 and its got under 35,000... I ordered my kit from gmpartsdirect and it was so much cheaper than everywhere else. I got the kit for 626.000 which is the cheapest i've found online...and thats shipped. But they say there is a nat back order
huh ??
NoBalt123
Sep 4, 2015 07:10 AM
