IAT fail
Old Jan 26, 2012 | 11:39 PM
mesame's Avatar
IAT fail
This is the mess of wires that I was left with after my run-in with a sign. I cant figure out what the green plug goes to.... I got the code read and I got P0096 which is the IAT Performance Sensor which I believe is built into the MAF sensor which is attached to my CAI. My car will not even start so I am at a loss what to do.
Old Jan 26, 2012 | 11:41 PM
zerosk8ter83's Avatar
doesnt that connect to the temp sensor?
Old Jan 26, 2012 | 11:42 PM
TommyP's Avatar
AWD > FWD
That wire should get plugged into the outside air temp sensor in the bottom of the driver side headlight bracket if that is what I think it is. Is your outside temp showing --- in the car?
Old Jan 26, 2012 | 11:45 PM
nhanson's Avatar
i know there are green plugs on injectors
Old Jan 26, 2012 | 11:46 PM
yes but Im pretty sure that connects to the temp sensor
Old Jan 26, 2012 | 11:49 PM
drumrush's Avatar
yup, temp sensor
Old Jan 27, 2012 | 12:37 PM
mesame's Avatar
(facepalm) Now that that's settled. My car still won't start. After I hit the sign I was driving with a bent injen CAI and it drove fine but it was exposed. We replaced the CAI, hood and bumper and now the car wont start or run at all. The only wires we touched were the ones in the picture above. I know the others go to the headlight, fog lamp, MAS and horn. Any ideas why it ownt start? I figured maybe if I reset the ECU? I think I was given bad instructions on how to do this.
Old Jan 27, 2012 | 12:38 PM
TommyP's Avatar
AWD > FWD
The bracket may not have the sensor in it.
Old Jan 27, 2012 | 12:47 PM
Staged07SS's Avatar
Administrator
Administrator
What the others have said.
IAT1 is read by the MAF sensor.
Old Jan 27, 2012 | 01:34 PM
mesame's Avatar
So if the bracket doesnt have the sensor what do I do.
Old Jan 27, 2012 | 01:39 PM
TommyP's Avatar
AWD > FWD
Get one from a dealer, or try Gmpartsdirect.com
Old Jan 27, 2012 | 01:52 PM
mesame's Avatar
How do you reset the ECU?
Old Jan 27, 2012 | 04:09 PM
wait wait check your fuses first to see if anything is blown
Old Jan 27, 2012 | 04:31 PM
mesame's Avatar
I checked the fuses and they are all fine. I believe.... Would getting the codes read indicate that the fuses were blown.
Old Jan 27, 2012 | 04:41 PM
ecot3c inside's Avatar
were you tuned? if so have your tuner write entire the tune again, that did it for me once.
Old Jan 27, 2012 | 05:11 PM
mesame's Avatar
No I wasn't tuned... Where do I do that? Also would that stop my car from starting?
yellow dragon
Sep 28, 2015 09:49 PM
Mugwump
Aug 26, 2015 02:31 PM
WopOnTour
Jan 22, 2015 02:08 PM
ENUFPWR
May 18, 2006 09:44 PM
