Issue When Getting Gas. (Car revs weird after filling)
Old Dec 17, 2009 | 04:24 PM
Billig ss/sc's Avatar
So I'm having this weird issue where every time I get gas when I start the car it only revs to 500rpm (feels almost like it's stalling) then shoots up to 2000rpm real quick. And if I'm just sitting in neutral it'll keep bouncing between 500-2200rpm for until I start driving. Even if I drive for a sec (like to merge back onto the road leaving the gas station) when I stop, it does it again. Typically once I'm driving for like 30 seconds and stop it'll be back to normal. I was also watching my gas gauge when I was filling up last time and it was bouncing around all over the place pretty fast (1/2 tank, then 3/4, then 1/2, then full, then 3/4 again, etc). Really weird. It only happens when I get gas, no other time.
Oh, and this started about a week and a half or so ago (filled up several times since then, I do a lot of driving for work).
Thoughts?
Old Dec 17, 2009 | 04:27 PM
08-cobalt-sport's Avatar
what kind of gas are you putting in your car
Old Dec 17, 2009 | 04:29 PM
93 octane (usually Shell or Sunoco, never no-name gas stations). I bought my car new almost exactly 2 years ago and that's all I've ever put in it.
JapEatr's Avatar
South Central *********
EVAP solinoid
Old Dec 17, 2009 | 04:30 PM
recklessactn's Avatar
Thats the same problem I was having but the gas pump wouldnt be able to pump sometimes. Turn on your car to the ON position and wait 10-15 seconds and then start the car, if it has a rough idle then turn it off and do this again and you should be fine. The fuel pump is just re-pressurizing the system. If your throwing a code it should be a EVAP code. My car is at the dealership now to get the solenoid replaced. code was P0496
Old Dec 17, 2009 | 04:32 PM
Originally Posted by JapEatr
EVAP solinoid
^^Details, please?
I've tried turning it to on (not the engine though) for like 15 seconds and starting it but never tried turning it right off. I'll try that next time.
How much is/was it to fix?
Last edited by Billig ss/sc; Dec 17, 2009 at 04:32 PM. Reason: Automerged Doublepost
Old Dec 17, 2009 | 04:37 PM
Gestapo007's Avatar
my car used to not start for 3 tries after i got gas and it was my EVAP purge solenoid. dealer replaced for no moneys
Old Dec 17, 2009 | 04:38 PM
Well my warranty expired at 36k or whatever so I'm f'd
Old Dec 17, 2009 | 04:43 PM
JapEatr's Avatar
30 buck part
to the right of the valve cover, has green cap on it.
Old Dec 17, 2009 | 09:26 PM
I'll check it out. Hard to replace?
Last edited by Billig ss/sc; Dec 17, 2009 at 09:26 PM. Reason: Automerged Doublepost
Old Sep 23, 2012 | 07:17 PM
StpdFstSS's Avatar
Mine just started this at only 64000 miles on it. It is an '06 though so maybe thats why. Gona check it this weekend.
Old Sep 24, 2012 | 01:15 AM
06SS ALL DAY's Avatar
It's your cams dood. Told you not to get em.
How to Guide
57
Oct 15, 2015 11:56 AM
Highgross89
20
Sep 11, 2015 03:24 PM
Getaway_Driver
40
Sep 10, 2015 09:11 AM
Sabon_SS
Sep 7, 2015 12:39 PM
