keyfob replace
You need to use a tech2, Usually only a dealer has one. The remotes going out is a know problem with the cobalts. The buttons have slowly stopped working on mine. I had to pull the horn fuse cause my remote was broke and the alarm wouldnt shut off.
thats what i plan on doing but i called the dealership and they wanted like 60 bucks to program it and that was a hell no. so 10 bucks thats a steal. have to all again and see what they say
this is what one of my cousins told me to do and see if it works
get in your vehicle and shut all the doors. Put your key in the ignition switch and hold down the "Unlock" button on your door panel.
Examine your ignition area closely. There are key settings besides cranking the engine: "off," "on" and "acc." Quickly toggle the key between "off" and "on" twice with the door unlock button held down.
Release the "unlock" button and listen for the doors to lock and unlock. This signals you are in programming mode.
Hold down the "lock" and "unlock" button on the keyless remote to program it to the vehicle. Wait for the doors to lock and unlock again to signal that the programming is complete.
Repeat the procedure to program a total of four remotes to your GM vehicle.
How to Program GM Keyless Remotes
eHow | How To Do Just About Everything! | How To Videos & Articles
What's wrong with your fob? The buttons were all worn out on mine, so I just bought a new one off ebay and swapped the controller boards.
broke battery tray holder off and the pin was still in the solder so i was screwed
agentirons
10-16-2015 02:11 AM
DANRICKARD
10-01-2015 12:08 AM
importkiller
09-30-2015 07:18 PM
