knock in front suspension!!
Old Nov 3, 2010 | 08:00 PM
PattyO's Avatar
I've got a mean knock going on in my front suspension on what sounds like the passenger side and a little on the driver side. its most noticeable in first and second, if anyone knows what it might be please help me out!!
Old Nov 3, 2010 | 08:05 PM
ssyellow's Avatar
I will admit I have recently got the same problem on my car. Occurs going over large or small bumps. I have heard it might be the control arm bushings and one of mine is cracked but ironically its for the driver side (noise is louder on the passenger side). OP, have you recenty been lowered?
Old Nov 3, 2010 | 09:21 PM
bluecobaltls12's Avatar
i had bad cv joints. and when im pulling out in first and second it clicks.
Old Nov 4, 2010 | 12:19 AM
Coblasts's Avatar
Most likely your Swaybar links.
Old Nov 4, 2010 | 08:45 AM
PattyO's Avatar
no its not lowered. and definatly not cv'.s im thinking swaybar links or maybe ball joints? i'll be sure to check those control arm bushings thanks
Old Nov 4, 2010 | 09:57 AM
2006CobaltSS12's Avatar
^This. I had the same issue and had my swaybar links replaced and now, no more noise.
Old Nov 4, 2010 | 10:07 AM
jrmotosports 88's Avatar
me too!!!! same problem.... i dont think its ball joints tho.... and cv's are fine, so are struts, control arms are good.... i never thought of sway bar links.... but i also notice it badly when i dry steer alil bit... its kinda like a song playing with a soft click.... please keep us informed of the problem save me some time when i go to fix the problem....
Old Nov 5, 2010 | 07:56 PM
PattyO's Avatar
The major knock ended up being the control arm bushing but the sway bar links also need replacing. i picked up the parts already and im goning to start tearing into it tommorow. is this a REAL big job? i've got a press at work i can use but i dont wanna bite off more than i can chew here....
Sl0wbaltSS
Nov 21, 2018 11:11 PM
OrangeCoba
Oct 1, 2015 10:00 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
