LNF p0451 p0496...
Old Nov 7, 2012 | 04:15 PM
umrdyldo's Avatar
Originally Posted by SSturb
ok so i tested my purge solenoid and its good. so what else could be the issue here?
I'm guessing you pulled it off and couldn't blow threw it. Can be stuck open or closed.
Could be the other sensor by the gas tank or a bad evap canister under the tank.
I'm still guessing the selenoid is bad. Just replace it and the sensor by the tank and see what happens. Dollars says it goes away. A whole dollar.
Old Nov 7, 2012 | 04:18 PM
SSturb's Avatar
a whole dollar? haha do you know the part number by the gas tank?
Old Nov 7, 2012 | 04:28 PM
umrdyldo's Avatar
https://www.cobaltss.net/forums/how-...-valve-240295/
GM part numbers:
Vent Selenoid - 25932573 - $32
Purge Selenoid - 12597567 - $41
Amazon Amazon
Amazon Amazon
Old Nov 7, 2012 | 04:34 PM
SSturb's Avatar
awesome dude thanks!!
Old Nov 7, 2012 | 04:42 PM
SSturb's Avatar
so before i go buy these parts you think i should try swapping out the purge solenoid? cause i already bought it and you said it could be stuck open or closed right?
Old Nov 7, 2012 | 05:13 PM
umrdyldo's Avatar
If money isn't a big deal then go ahead and swap. Dang thing is going to fail anyway.
After how many i have been through and seen on here, I would say 8 times out of 10 it's the manifold sensor before the vent valve by the tank. 496 is the same code matching almost every thread about Manifold purge valve failure.
Old Nov 8, 2012 | 01:09 AM
Nevacme's Avatar
Ive had allllllll three codes and tha solenoid was 100% tha problem
Old Nov 8, 2012 | 12:23 PM
SSturb's Avatar
ok so i drove around for a little bit today then check the purge valve again and it was open and i could blow thru it! I swapped it with a brand new one and i think i am good to go! hopefully its just that (which Im sure it is) and not the other valves by the tank! thanks for the help
Old Nov 8, 2012 | 12:25 PM
umrdyldo's Avatar
That's good to hear. For those wanting to keep their car for awhile should probably stock up on these bastards. 3 in 36 months is stupid.
Old Nov 8, 2012 | 12:29 PM
SSturb's Avatar
yeeah i bought 4 just in case
Old Nov 8, 2012 | 03:39 PM
  #36
SSturb's Avatar
so i just went out to run a few errands and i floored in in 2nd and a CEL flashed a few times and went away. what is that all about? ive never had it just flash. car feels fine
Old Nov 8, 2012 | 04:19 PM
  #37
umrdyldo's Avatar
If car wasn't warm then you are having misfires. I have never had it happen on my car but shouldn't floor it till up to temp.
Old Nov 8, 2012 | 04:55 PM
  #38
SSturb's Avatar
it was definitely warm
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
patooyee
Oct 1, 2015 01:07 PM
cw383
Sep 30, 2015 12:41 AM
