m6 no boost help please
Old Apr 3, 2015 | 06:10 PM
The Rookie24's Avatar
need help asap my lsj is making 5 psi I've changed the bypass solenoid the vacuum lines the boost actuator new belt and still nothing I've had the sc off and checked it the rotors are clean and the butterfly valve moves easily so what else is left I'm at a lost
Old Apr 3, 2015 | 06:26 PM
DevZX's Avatar
Good luck justin... lol
Old Apr 3, 2015 | 07:27 PM
Superbolt's Avatar
Air filter.
Old Apr 3, 2015 | 07:40 PM
DevZX's Avatar
Originally Posted by Superbolt
Air filter.
I doubt it.. i had a k&n drop in filter that was absolutley cover in dirt, bugs, and leaves and was causing my car to misfire like crazy but still hit about 10lbs of boost.. you said you recently changed your filter right Justin?
Old Apr 3, 2015 | 07:42 PM
Superbolt's Avatar
Just throwing it out there to check.
Easy stuff first.
Old Apr 4, 2015 | 12:41 AM
checked the filter its good so this is what I've done puled the sc off rechecked the butterfly valve the rotors and sc gasket all are good has new belt all new vacuum lines bypass solenoid and tried a boost actuator from dev and stilll would only get 5 psi its all stock pulley wise and the tension seems good I'm gunna zip tie the butter fly valve shut and see if it build boost
Old Apr 4, 2015 | 09:59 AM
Superbolt's Avatar
what kind of vac lines did you use ? if they are just regular hose they are not strong enough to handle the vacuum that could be the problem. you need oem or a thick wall hose.
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
tomj77
Oct 4, 2015 11:39 AM
717ssbalt
Oct 2, 2015 04:01 PM
