MAF DTC Codes
Old May 3, 2012 | 10:01 AM
Cuda009's Avatar
MAF DTC Codes
Hello,
I started to get some codes going into the winter last year. The codes are P0100, P0102, and P0103. They went away over the winter and have come back with the warmer weather. I've cleaned and replaced the MAF and I see no obvious damage to wires around the MAF. It has thrown P0108 and P2261 once.
The car will boost occasionally but usually sits at 2-4psi. On the way into work this morning, it didn't boost for the first 7 miles, parked it, turned it off, turned it back on, codes came up and started boosting again. I don't hear any obvious boost leaks. Any suggestions would appreciated. Thanks.
Old May 3, 2012 | 10:26 AM
Gremlin85's Avatar
Couple questions for you first:
What mods (if any) do you have? Intake? Tune?
Have you checked for boost leaks? Cracked intercooler or charge pipes? Loose couplers?
Old May 3, 2012 | 10:54 AM
Cuda009's Avatar
It's a 2008 SS/TC with the Stage 1 Kit and a catback Hahn exhaust. I also changed the air filter to rule out the air filter.
I did not notice any damage to the intercooler. I checked all the couplings and none seem loose. My next step was to take it in for boost testing at a local shop or to the dealer, but wanted to see if there's any more suggestions.
Old May 3, 2012 | 12:56 PM
Chevrolet Cust Svc's Avatar
Keep us posted, Cuda! Hope you're able to find a resolution soon, and if you go to a dealer, I'm always here if you have any questions.
Best,
Sarah
GM Customer Service
Old May 16, 2012 | 03:57 PM
Cuda009's Avatar
OK, small update. I've noticed this only happens when I'm in vacuum. If I sit around -8 psi, the engine sputters and drops to about -12 psi. If I floor it at this point, I'll get up to about 2psi of boost and no more. If I let off the gas for a couple seconds and floor it straight out, I boost just fine. In my limited (none) knowledge of engines, I'd say either a boost or vacuum leak.
Old May 16, 2012 | 04:07 PM
ecotecturbo's Avatar
Bring it to the dealer you still have a warranty. Your intercooler is cracked i bet. How many miles do you have now?
Old May 16, 2012 | 05:24 PM
Cuda009's Avatar
65k. A cracked intercooler isn't going to be covered under warranty.
Old May 16, 2012 | 10:41 PM
I know that but if its throwing codes and not boosting bring it in and see what they say.
Old May 23, 2012 | 10:05 PM
Cuda009's Avatar
Broken wire near the MAF was the problem. Car seems to be fixed from the drive home from the dealership.
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
tomj77
Oct 4, 2015 11:39 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
