NEED HELP!! My car is loseing BOOST!
Old Jan 13, 2007 | 08:08 PM
srt-killer's Avatar
I have a 2.7 pulley and meth injection, about a month ago i use to see up to 19psi on the meth but latly i can't get more than 16psi on the meth and when the meth is off i only get 13-14psi. at redline! You can tell the car has lost power. I don't think its belt slip cause i do have the stage 2 belt, a non-slip pulley, and my boost doesnt fluxuat like if the belt was sliping. Does anybody have any idea what could cause this? Please help any imput will be appreciated!
Old Jan 13, 2007 | 08:12 PM
Mstumpy06's Avatar
maybe a leaking gasket? could be loosing boost through that
DWK5150's Avatar
Did you check for leaks like intake or SC gasket??
Old Jan 13, 2007 | 08:17 PM
srt-killer's Avatar
No i havn't checked any of my gaskets because i would think it would idle funny but mine idles fine. Boost build up to 14psi like nothing but it just doesn't go anywhere after that. Ive noticed it getting worse and worse.
Old Jan 13, 2007 | 10:23 PM
zinner's Avatar
Moderator Alumni
any exhaust mods? I lost a 2 psi from a hi flow CAT...
Could be that your rotors are messed up. Pull it off and take a look at em.
Old Jan 14, 2007 | 05:57 PM
srt-killer's Avatar
I do have an exhaust, 3" downpipe no cat and 3" side exit, but ive had that for awile and i use to see the 19psi with my current setup untill lately. Could the meth affect the rotors?
Old Jan 14, 2007 | 06:04 PM
Ljavy17's Avatar
how long have you had meth for.
Old Jan 14, 2007 | 06:07 PM
CTORANGESC's Avatar
The meth maybe the problem, but take cyclo or carb clean and spray all the gaskets, if the idle raises then you know you have a leak.
Old Jan 14, 2007 | 06:11 PM
astrocrep's Avatar
yea, if you sucked in some dirt or something and scratched the bottom of your rotors blades you could easily be losing boost.
-Rich
Old Jan 14, 2007 | 06:13 PM
Ljavy17's Avatar
Meth could deff hurt the rotots. But in the loooooooooooooooooooooooooooooong run
Old Jan 14, 2007 | 06:29 PM
Cobalt_Supercharged's Avatar
If you are spraying pre blower it could be eating the rotor coating. Could it be the bypass actuator diaphram?
Turbo Johnny
Feb 21, 2019 09:41 AM
The Rookie24
Sep 14, 2015 07:03 PM
Highgross89
20
Sep 11, 2015 03:24 PM
Getaway_Driver
25
Sep 5, 2015 09:16 PM
