Need help and opinion
Old Jan 20, 2010 | 05:15 AM
AndrewTT's Avatar
Exclamation Need help and opinion
ok so i have a cobalt ls 2.2 and i was changing out the camshaft cover seals becuz i had a small compression leak in cylinder four and was told that this may be the problem while doing this i got the cover off and realized that two camshaft followers and a hydraulic lash adjuster was blown apart across the engine on the exhaust side. Didn't have any problems performance wise im assuming cuz its dual over head cam so exhaust was still going out just on one valve. anyways i got those replaced and made the mistake of not timing the car correctly..i started it and it made a weird noise obviously and i immediatly shut it down maybe was on for like 3-4 sec. So my question is ..is everything ok and should i just go have it timed properly at a dealer or do u think some valves may be bent.. i did take off the intake manifold and no valves were bent on that end..opinons plz i would love to start driving my car again but its been garaged due to this and becuz its the winter so what do u think
Thanks..
Tupp
Sep 30, 2015 08:18 PM
importkiller
Sep 30, 2015 07:18 PM
dasoftest
Sep 29, 2015 02:14 PM
reybalt
Sep 22, 2015 06:35 PM
Haily229
Sep 17, 2015 07:18 AM
