odd boost needle?
Old Apr 22, 2014 | 01:34 AM
josh6854's Avatar
odd boost needle?
I'm wondering if my car is tryin to boost more than should. For instance when I take off from 1st 2nd it seems to jump to to high between shifts. I'm shifting at 25k.
Old Apr 22, 2014 | 07:08 AM
LNFTX's Avatar
Holy hell what kinda valve springs you runnin?
Old Apr 22, 2014 | 08:51 AM
BlackielawlessSS's Avatar
25k rpm holy crap!
Old Apr 22, 2014 | 09:25 AM
This is not the problems section of this forum just a fyi. (You want to post in problems and maintenance sub-forum).
More information is needed for anyone to give help/advise
Old Apr 22, 2014 | 09:45 AM
I am betting a clogged cat.
Old Apr 22, 2014 | 10:25 AM
Good chance that's what it is, but given the lack of info going straight to clogged cat is difficult since we don't know what pulley/tune and what his WOT boost is
Old Apr 22, 2014 | 10:44 AM
Very, true. I think mine is clogged or it is my fuel filter.
Old Apr 22, 2014 | 12:22 PM
josh6854's Avatar
I just installed zzp 3" full exhaust with dp and high flow cat a month a ago. 2.9 pulley with 60# inj and h/e.
ALSO, I know I'm needing engine mount and crank relearn.
Old Apr 22, 2014 | 03:02 PM
insylem's Avatar
What kinda mods do you ahve to shift at 25, 000 RPM???
Dang!
My RPM gauge only goes to 8, 000 RPM With a rev limiter at 7, 000 RPM.
Old Apr 22, 2014 | 03:23 PM
josh6854's Avatar
Dang!
Dude.. my bad 2.5 grand better?
Old Apr 22, 2014 | 03:25 PM
josh6854's Avatar
Could my valve on the sc be the issue? A friend once before was tryin to adjust it
Old Apr 22, 2014 | 03:57 PM
LNFTX's Avatar
Im confused
Why is there any boost if your doing a 1-2 shift at 2.5k?
Wot short shift?
I dont know too much about lsj and how bypass and the tune works and such but if I am putting along granny shifting at 2.5k there's no boost.
Hell if your shifting it that low you could be causing it to bog down
Old Apr 22, 2014 | 06:15 PM
josh6854's Avatar
I thought shifting at 3k was high but maybe I should try it. It just seems like my needle jumps into boost to soon like around 3-5psi
Old Apr 22, 2014 | 07:12 PM
insylem's Avatar
3- 5 being high? Dude Stock is 12.5 PSI boost....
Old Apr 22, 2014 | 08:01 PM
Agreed 3-5 is not high. Does the lsj control boost off throttle/load?
Old Apr 22, 2014 | 09:38 PM
josh6854's Avatar
I'm boosting over that its just seem its boosting to soon. I think the my buddy adjusted my valve on the sc and its allowing it to boost when it shouldn't
I try to keep it out of boost riding around town but its hard with it trying to hit into boost
Old Apr 22, 2014 | 11:55 PM
LNFTX's Avatar
Is it making any boost at idle
Old Apr 23, 2014 | 12:40 AM
josh6854's Avatar
No just when I take off threw the gears it seems the needle reaches boost to easily like around5-7 psi. Its almost impossible to stay out of boost just daily driving it. My friend says it could be the bv on the sc was somehow adjusted and throwing my boost levels off.
Old Apr 23, 2014 | 02:14 AM
insylem's Avatar
That sounds about normal
There is a tune option that ZZP offers that I have where it reduces boost by 50% in 1st gear.
Old Apr 23, 2014 | 05:27 AM
REDi DEViSTATOR's Avatar
Just drive the damn thing. Yew haz tinee pew lee noa. It makes boost easy. So?
Old Apr 23, 2014 | 10:19 AM
josh6854's Avatar
Ok thanks guys and Insylem I'll check on that
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
tomj77
Oct 4, 2015 11:39 AM
717ssbalt
Oct 2, 2015 04:01 PM
