Odd issue
Old Nov 23, 2009 | 08:01 PM
_UnLiMiTeD_'s Avatar
Odd issue
Over the past few days, when i go to get out of my car after i turn it off, the door wont open. The handle just moved loosely like its broken, from the inside and outside. But if i lock it then unlock, i hear a wierd metal cling by the handle and it works fine again.
Also if it does that when the door is open, then the door will not close shut until i lock, then unlock it again.
It doesnt always do this, every 2nd time i go to get out of the car and it just started a few days ago
Old Nov 23, 2009 | 08:05 PM
boostedss26's Avatar
My wifes car did it. Warranty covered a new latch
Old Nov 23, 2009 | 08:13 PM
no warranty for me... grr
Old Nov 23, 2009 | 08:20 PM
Well now you know whats wrong atleast lol
Old Nov 23, 2009 | 08:23 PM
Collin's SS's Avatar
happend to me three times in four years, there is a how to on fixing this. myself i never fixed it, always used my key FOB; hit lock and unlock and it fixed itself...
Old Nov 23, 2009 | 08:26 PM
OrngBalt's Avatar
Dude... hate to say it but search would answer this. VERY common problem. the latch gets stuck. It just needs some grease and you are all set. You shouldn't even need a warranty to fix it, its such a common mistake and such a simple fix that the dealer should do it for you free of charge.
Old Nov 23, 2009 | 08:34 PM
pull off the door panel and grease it or just spray grease through?
Old Nov 25, 2009 | 09:35 PM
i couldnt find any write ups on this fix. Where am i spraying it. Do i need to pull the door panel off to spray in somewhere. I have sprayed into the latch outside the door and it still does it
Old Nov 25, 2009 | 10:28 PM
Mr_Slobalt's Avatar
probably gonna have to fork over the money for a new latch unfortunately
lubing and working the latch may help your issue, but it's temporary
I just replaced mine a few thousand miles ago
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
