P0420 Code
Old Apr 2, 2012 | 07:23 PM
aquaman3680's Avatar
P0420 Code
Installed a Injen CAI and 2.5" ZZP Catless down pipe on my LE5 2.4l over the weekend. I am now getting code P0420 which I assume is from removing the cat. I am planning on getting a tune here in a couple weeks and am assuming I will need to delete the rear o2 sensor. I guess my question is will it cause problems running with that code for a couple weeks until the tune? Or is there another fix for this code?
Thanks,
Matt
Old Apr 2, 2012 | 07:29 PM
advise's Avatar
no performance issues just a annoying light
Old Apr 2, 2012 | 08:14 PM
nhanson's Avatar
I took my rear O2 and stuck my wideband in there.
Old Apr 2, 2012 | 08:22 PM
TommyP's Avatar
AWD > FWD
Delete te code when you get it tuned, otherwise just ignore it
Old Apr 3, 2012 | 12:19 AM
Yes it is an annoying little light! Was talking to the tuning shop and apparently they freak out about the CEL's and said they wouldnt touch the car with it on there. I guess just tell them all it needs is a rear o2 sensor delete?
Thanks for the input! I appreciate it!
Old Apr 3, 2012 | 02:21 AM
bluebalt07's Avatar
Or just take it somewhere like autozone and have them scan and clear the codes
Old Apr 3, 2012 | 01:06 PM
Took it to autozone and they couldnt read my ecu. That was odd. So I took it to a tuning shop and they had no problems, cleared the code, and came back within 10 miles :/
Old Apr 3, 2012 | 01:26 PM
royce777's Avatar
yeah the code will come back on right away
Old Apr 3, 2012 | 01:27 PM
Mindrot's Avatar
Clearing the code won't make it go away. The code itself needs to be deleted via HPTuners. Its nothing to be worried about. The only harm it will do is if you get emissions run on your car. It will fail obviously. However I don't think you care about emissions since you went catless lol
Old Apr 3, 2012 | 01:29 PM
SaberD's Avatar
spark plug non fouler trick. i had to add a 90 degree elbow to mine in addition to the non fouler trick to prevent the code from returning. you can clear the code simply by unplugging the battery.
Old Apr 3, 2012 | 01:31 PM
startingline05's Avatar
lol p0420 code.
Old Apr 3, 2012 | 02:38 PM
Mindrot's Avatar
Originally Posted by startingline05
lol p0420 code.
If only we had a nickel for every p0420 code thread
Old Apr 3, 2012 | 02:41 PM
Yeah no emissions tests in Kansas
Hey, at least I read quite a few threads about it to find out what it was and what causes it. Just wanted to make sure it was fine running for a few weeks with that code!
Old Apr 3, 2012 | 02:42 PM
Mindrot's Avatar
Haha no worries
Old Apr 3, 2012 | 02:44 PM
Haha the guy that checked the code laughed his ass off when it came up, obvious pothead (nothing against that) but he was envious that I had a 420 code. haha
Old Apr 3, 2012 | 03:06 PM
TommyP's Avatar
AWD > FWD
You went to a tuning shop that was afraid to work on a car with a p0420 code? I would have left. A real "tuning" shop should be used to working on cars without cats.
Old Apr 3, 2012 | 03:09 PM
Nah I called and was asking about how much a tune would be before I had verified the p0420, told them it was most likely a p0420 and they said they wouldn't touch the car until it was taken care of or checked out further. Which I think would be normal.
Old Apr 3, 2012 | 03:12 PM
TommyP's Avatar
AWD > FWD
Oh ok if they didn't know what code it was beforehand that's understandable. They don't wanna deal with somebody else's broken car, people sometimes go to tuning shops to get work done then blame preexisting conditions on the tuner.
Old Apr 13, 2012 | 12:25 PM
MyOtherSS's Avatar
Where'd you find a 90 degree elbow? i'm about to do the same thing.
turbochargedss2012
Sep 20, 2023 12:17 PM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
