Problems after MAF replacement
Old Dec 4, 2019 | 12:49 PM
GullySS's Avatar
My car went into limp mode and threw a p0101 for a bad Maf sensor, so I replaced it. All the power is back and the cel didn’t come back on. But now my throttle lags when revving it up to get in gear. Also when downshifting and decl the car is back firing way more then it used too. There are no codes for this problem. Bad fuel filter maybe? Going to try a throttle relearn.
2009 Chevy Cobalt SS/TC no tune.
Old Dec 4, 2019 | 01:11 PM
That code usually means you have a boost leak. So you probably replaced the maf for nothing.
Old Dec 4, 2019 | 04:53 PM
GullySS's Avatar
Yes but the cel has not came back yet after 4+ hours of driving and I make complete boost.
also A/F are fine
Old Dec 4, 2019 | 05:03 PM
Step 1 for P0101 is always boost leak test. Even if it doesnt seem like its leaking it could be.
Very low chance, but you couldve had a leak at the MAF itself that was fixed when you replaced it.
Old Dec 4, 2019 | 05:05 PM
steelmesh's Avatar
also A/F are fine
If you have a boost leak then your wastegate shuts more than usual trying to achieve your target boost by spinning your turbo faster to compensate for the lost flow, so it's possible with a small leak you wouldn't notice lowered boost pressure; but I'd expect the ECU should pick up on this and throw another code eventually so keep your eyes open.
Before continuing to run the engine, you should do a focused once-over of the boost tract and look for weird stuff like melted, cracked, or loose things.
JimmySpencer
Nov 16, 2015 11:47 PM
mikeluis92
56
Apr 5, 2015 01:04 PM
c0de7477
May 31, 2014 02:02 AM
bspeed
Oct 28, 2011 02:07 PM
CobaltMcgee
Oct 18, 2011 11:54 AM
