Pulley Size
Old Mar 20, 2014 | 04:13 PM
dtec's Avatar
Pulley Size
hey guys, I downgraded to a stock sized pulley today, and my mechanic called me saying that he got the new belt and pulley on, but said that the belt barely fit on there and he really had to struggle when doing so. I wanted to know, since the stock pulley i got was from a 4 door ss/sc would it make a difference since my car is a 2 door? its the same engine right? what reasons do you think the belt was so hard to put on? its a Dayco belt and he double checked, its the correct size. I dont want anything breaking because its a tight fit. Thanks.
Old Mar 20, 2014 | 04:18 PM
WVU_SS's Avatar
I didn't know they made a 4 door LSJ???
Old Mar 20, 2014 | 04:35 PM
Gelladuga69's Avatar
Sounds like you went up in pulley size from stock.
Old Mar 20, 2014 | 04:51 PM
dtec's Avatar
Ok nvm the 4 door thing
Old Mar 20, 2014 | 07:44 PM
mrbelvedere's Avatar
try using the search button
Old Mar 20, 2014 | 08:04 PM
BlackielawlessSS's Avatar
Wait i want a sedan lsj!
Old Mar 20, 2014 | 08:07 PM
No you dont
Old Mar 20, 2014 | 08:21 PM
Spawne32's Avatar
you are by far the most useful member on this board
Old Mar 20, 2014 | 09:06 PM
dannysauer's Avatar
They never made a 4 door LSJ and what does the pulley look like and was it pressed on cuz it would have to be if stock no bolts on it plus u can break out a tape measure and solve this problem
Old Mar 21, 2014 | 08:28 AM
you are by far the biggest bitch on the board
Old Mar 21, 2014 | 08:38 AM
CSRT4U's Avatar
I do like fig newtons
Old Mar 21, 2014 | 09:51 AM
LOL. MrB got you
Old Mar 21, 2014 | 09:54 AM
yellowsupercharged06's Avatar
he is from LI
Old Mar 21, 2014 | 09:56 AM
08baltls's Avatar
The problem is, the LSJ has a smaller crank pulley than the L61/LE5(I think on LE5). So a stock belt is going to be a bitch to put on, on a stock pulley, with a stock crank pulley. Im on a 3.1, which should use a GM stage 2 belt, but I have to use a stock belt size and it damn near maxes out the tensioner. So theres you answer as to why you're having problems getting the belt to fit.
Old Mar 21, 2014 | 10:28 AM
wayfarer's Avatar
Since you said *downgraded to...* I'm assuming you had a smaller pulley before--- you sure you don't have an oversized tensioner pulley?
Old Mar 21, 2014 | 11:03 AM
Spawne32's Avatar
LOL. MrB got you
Old Mar 21, 2014 | 11:09 AM
who had the popcorn. I want some.
Old Mar 21, 2014 | 07:10 PM
dtec's Avatar
Thank you, I understand now
Oct 20, 2015 09:56 PM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
