Radio not turning off when door opens
Old Dec 17, 2013 | 12:40 AM
Isamu's Avatar
I have an 09 SS and all of a sudden today the radio decides not to turn off when I open the door with the car off. The dome light also does not turn on with the door open. I tried disconnecting the battery for a couple minutes and that did not seem to help. I have resorted to pulling the fuse so it doesn't kill my battery.
Any suggestions?
Old Dec 17, 2013 | 12:55 AM
Theres a button kind of deal that gets pushed in when the door closes id check that area out make sure the button is moving freely
Old Dec 17, 2013 | 06:53 AM
joshcsepegi's Avatar
Yeah just a door pin switch they are like 7.00 at advance.
Old Dec 17, 2013 | 06:57 AM
LS6Rally's Avatar
what they said lol
Old Dec 17, 2013 | 08:30 AM
What i said
Old Dec 17, 2013 | 11:31 AM
Isamu's Avatar
Lol ok thanks I will try that
Old Dec 17, 2013 | 09:42 PM
hotrdr's Avatar
Real simple. take out switch right below door check in front jam. turn key on then off. radio should be on. when you touch that wire to chassis ground ....meaning just a paperclip between the 2 wires on switch...if radio turns off..dome lights work you need a switch. if it doesn't work...check wires from switch to body control module. if they are ok you need a bcm. chances are they will turn off = bad switch. could be bad groumd but that would mean your windows and mirrors and locks wont work either
Old Dec 17, 2013 | 11:29 PM
What he said
06MetallicBalt
Jul 20, 2025 08:47 PM
Solaris99
28
Mar 15, 2017 01:22 PM
agentirons
Oct 16, 2015 02:11 AM
Oct 13, 2015 09:32 PM
roth
Sep 26, 2015 12:16 PM
