Replacing lifters
uhhh ive done it, just make sure you take one out at a time, very difficult but easy lol...
It took me about 1 1/2 hours
Last edited by Chevycobaltss3; Apr 2, 2010 at 02:05 PM. Reason: Automerged Doublepost
Heres some info for you !
Tools Required
J 43655 Camshaft Sprocket Holding Tool
Removal Procedure
Remove the camshaft cover. Refer to Camshaft Cover Replacement .
Remove the upper timing chain guide.
Install the J 43655 .
Remove both the intake and exhaust camshaft sprocket bolts and discard.
Slide the camshaft sprockets forward.
Mark the caps to ensure they are installed in the original position.
Important: Remove each bolt on each cap one turn at a time until there is no spring tension on the camshaft.
Remove the caps.
Remove the camshaft.
Remove the camshaft roller followers.
Remove the hydraulic lash adjusters.
Installation Procedure
Lubricate the valve tips.
Install the hydraulic lash adjusters.
Install the camshaft roller followers.
Ensure that the alignment notches are aligned with the camshaft sprocket.
Install the camshaft.
Install the caps.
Notice: Refer to Fastener Notice in the Preface section.
Tighten the camshaft bearing cap bolts in increments of 3 turns until they are seated.
Tighten
Tighten the camshaft bearing cap bolts to 10 Nˇm (89 lb in).
Apply a 3.5 mm (0.138 in) bead of sealant to the rear cap. Refer to Sealers, Adhesives, and Lubricants for the correct part number.
Install the rear intake camshaft bearing cap bolts.
Tighten
Tighten the bolts to 25 Nˇm (18 lb ft).
Install camshaft sprockets onto the camshafts.
Hand tighten NEW camshaft sprocket bolts.
Remove the J 43655 .
Tighten the camshaft sprocket bolts.
Tighten
Tighten the bolts to 85 Nˇm (63 lb ft) plus 30 degrees.
Install the upper timing chain guide.
Tighten
Tighten the upper timing chain guide to 10 Nˇm (89 lb in).
Install the camshaft cover. Refer to Camshaft Cover Replacement .
Tools Required
Removal Procedure
Remove the caps.
Install the caps.
Tighten
Tighten
Tighten
Tighten
this man right here above me coblasts is correct on every work, the right way not the fast way but there are back roads you can take to do the lifter, do i recommend it to some young kid who has no experience, no! to some one of age and who is expereinced, yes!
Well I just installed 1 of 2. The hardest one, the top left. I unbolted the camshaft guides, 5<4<3<2<1. Rose the camshaft up ever so slightly, just enough to stick in the lifter. Slipped in the lifter and rocker arm, and reinstalled bolts.
Going to do it again tomorrow with the lifter just to the right of the one today.
Thoughts?
Thoughts?
Yeah I hope this is my only problem. I doubt i'll drop a lifter in there but good thing theres plugs in the holes so I lose them forever and cost more money.
Thats exactly how mine sounded... Like EXACTLY. Then it blew a 2nd lifter and it was done. But I fixed it today! Sounds just like it used to. Its been 5 months since it has sounded like this. Sounded pretty cool as a Subaru though, but I knew something was wrong. I'm just glad its all over now.
Kinda miss my Ubaru sound though, idk mine sounded cool as ****, but I knew something was wrong all along. I have a few threads on people trying to help me diagnose the sound. So far I've replaced my entire exhaust, spark plugs, intake, and like 99999 gaskets. Just to crack open the valve cover and find the real problem. How long did you wait before you even thought about redlining it again?
However earlier we had a oil leak we could never find, would coat the turbo and have the smell of burning oil for the 2 years we have had the car.
Well we pulled of the turbo to check if it was leaking, we also pulled the rocker cover off as well. Suprise!
One exhaust lifter on cylinder three broken, cracked cylinder head too (explains oil leak it must of been cracked for ages) explains the Subaru sound!
agentirons
Oct 16, 2015 02:11 AM
DANRICKARD
Oct 1, 2015 12:08 AM
importkiller
Sep 30, 2015 07:18 PM
