running lean??
Old Apr 15, 2014 | 07:22 PM
josh6854's Avatar
running lean??
Is oil pressure affected if your car runs lean
Old Apr 15, 2014 | 07:32 PM
Not unless your car stalls
Old Apr 15, 2014 | 09:39 PM
mrbelvedere's Avatar
or it runs hot from being lean
Old Apr 15, 2014 | 11:14 PM
josh6854's Avatar
Does 130+ sound out of range for my oil pressure?
And this sounds like this could be my issue?
Old Apr 15, 2014 | 11:15 PM
Thats like triple of what it should be. Sounds like a huge restriction somewhere.
Old Apr 16, 2014 | 08:09 AM
sounds like the bypass valve is not working I would change the front cover
Old Apr 16, 2014 | 11:54 AM
josh6854's Avatar
The round black canister that sits on the sc?
Old Apr 16, 2014 | 02:13 PM
show me where I said blower at I said I would change the front cover as the bypass valve is not working your high oil pressure has nothing to do with the blower the oil pump has a bypass/pressure relief valve and the oil pump and the bypass/relief valve is located on the front cover you need to pay attention
Old Apr 16, 2014 | 02:37 PM
mitchk90's Avatar
^ this guy lol.
Old Apr 16, 2014 | 03:23 PM
what about it
Old Apr 17, 2014 | 02:28 AM
josh6854's Avatar
Seriously if you are so aggravated by something I'm tryin learn and benefit from then why don't you just not comment on any of my threads. I'm thinking your talking about the round piece on the sc but apparently I'm wrong Mr Smartguy
Old Apr 17, 2014 | 08:45 AM
im not aggravated but you need to learn how to pay attention how do you get that the ******* bypass valve on the blower is your high oil pressure problem when I said to change the front cover due to the bypass in the oil pump is not working you need to get thicker skin mrs puss puss
Old Apr 18, 2014 | 12:15 AM
josh6854's Avatar
Are you still here? Actually your the same guy on my other threads that still had to comment smart___ posts on them as well. Maybe you need to get off the forum since you know more than anyone on here. I'm learning to all of this performance didn't know it was test taking time on here.
Old Apr 18, 2014 | 07:21 AM
mrs puss puss you need to learn which sections to post in your post belongs in problems and service not the performance section the performance section is about getting maximum performance out of the engine not help me my car is broken that section is called Problems/Service/Maintenance
Old Apr 18, 2014 | 12:22 PM
sLAsh's Avatar
I don't understand why you are so aggravated.
First of all you have had three years to learn where to post so there is no reason for this post to be in this location.
Mr B is one of the more knowledgeable people here and while he can be a cantankerous bastard at times he gave you a clear answer on where to look. You choose not to think logically about what he told you and just spit back the first random thing that came into your head. He could have just said yes, or no I meant the one on the steering wheel but instead he gave you a little slap for being an idiot and still gave you the answer you needed. You decided to get all butt hurt for him showing you the respect you deserve.
Mr B chooses to be one of the forum police here and helps keep the place from becoming nothing but 1000000000000 posts about what intake should I get. It's not a job I would want but I appreciate his effort. Without people like him most of the knowledgeable guys will leave. You will still get answers but they will be mainly guesses or uninformed.
Old Apr 18, 2014 | 12:44 PM
Staged07SS's Avatar
Administrator
Administrator
Well said!!
I like the idea of forum police. I will have to run that by the admins.
Old Apr 18, 2014 | 03:23 PM
let me see your badge officer
turbochargedss2012
Sep 20, 2023 12:17 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
tomj77
Oct 4, 2015 11:39 AM
dieGone
Oct 1, 2015 06:27 PM
DocSvensk
Sep 27, 2015 02:24 PM
