running rich (p0172) after cold air intake
Old Apr 1, 2015 | 08:17 AM
DevZX's Avatar
Hey guys so i put an ebay cold air intake with dryflow filter and injen hydroshield on and shortly after i get a p0172 code.. i thought you get a lean code from cold air intakes? Could the filter not be sucking in enough air? Should i try replacing the filter with a k&n? Or would you think a tune would fix it? Thanks! Btw its an lsj balt
Old Apr 1, 2015 | 10:28 AM
dannysauer's Avatar
Could just be the eBay intake have not heard a lot of good things about them should have just done the stock air box mod would have been better
Old Apr 1, 2015 | 12:24 PM
Staged07SS's Avatar
Administrator
Administrator
This.
Old Apr 1, 2015 | 12:27 PM
double clutch's Avatar
See if you can return it and do an air box mod like staged has. It will flow way better than an ebay intake
Old Apr 1, 2015 | 01:34 PM
DevZX's Avatar
Would i be able to use the stock paper airbox filter with the airbox mod? I probably wouldnt need a hydroshield with the airbox mod right? My hydroshield is too small and would rather not buy another one if i dont have too..
Old Apr 1, 2015 | 01:36 PM
This.
You should put the how-to as a link in your sig
Old Apr 1, 2015 | 01:56 PM
Staged07SS's Avatar
Administrator
Administrator
If you modify your box like mine, than yes, you can use the factory air filter.
No hydro shield needed. The box will provide adequate water protection.
but it's super top secret!!! lol
Old Apr 1, 2015 | 02:25 PM
DevZX's Avatar
Awesome! So you only drilled holes on the bottom cover? Did you get any codes from this?
Old Apr 1, 2015 | 02:27 PM
no_ss's Avatar
Is the stock airbox mod able to be done to the LNF stock intake?
Old Apr 1, 2015 | 02:54 PM
There is one, but its not like the LSJ.
Old Apr 1, 2015 | 03:58 PM
no_ss's Avatar
well I just went off on my own and did my own thing. It's not the prettiest but I made sure there was no hanging/loose plastic and washed it all out and ground off all excess plastic. I just need a drop in filter now and I'll order that Friday. Can hear the turbo a little more now, just needs to be opened up with the filter now.
Old Apr 2, 2015 | 07:07 AM
Staged07SS's Avatar
Administrator
Administrator
Yes only drill holes on the bottom cover.
Never had a code from the modified box or any intake on my car.
Builttss
Oct 4, 2015 10:21 AM
Sep 27, 2015 08:53 PM
DocSvensk
Sep 27, 2015 02:24 PM
roth
Sep 26, 2015 12:16 PM
OrangeCoba
Sep 25, 2015 06:06 PM
