Rust warranty?
Old Feb 5, 2012 | 03:19 PM
andywmu's Avatar
Rust warranty?
I own a 2007 LS, and the bottom of the doors are starting to bubble and rust already.
Is this covered under the paint/rust warranty for 6 years?
Old Feb 5, 2012 | 03:22 PM
TommyP's Avatar
AWD > FWD
I would hope so, I would say it falls into the paint/rust category. Worst you can do is call the dealer and they say no.
Old Feb 5, 2012 | 03:28 PM
andywmu's Avatar
Well problem is the dealers down here are pathetic and won't fix anything...i've barked up customer service's tree a thousand times about it.
I normally take it to the other side of the state to a dealer I used to work for and they will help me out...
So just wondering if this qualifies as a warranty repair and if it is worth the drive.
Old Feb 5, 2012 | 03:29 PM
nhanson's Avatar
Keep your car cleaner?
Old Feb 5, 2012 | 03:31 PM
andywmu's Avatar
That's the sad part... I am OCD about being clean, yet it doesn't help under the door for this car.
Old Feb 5, 2012 | 03:32 PM
BPacak's Avatar
Vtec Rep
theres a paint/rust warranty
Old Feb 5, 2012 | 03:34 PM
nhanson's Avatar
5 years i think and unlimited miles
Old Feb 5, 2012 | 07:51 PM
andywmu's Avatar
6yr/100,000 Miles.
It states it needs to be rusted through though, so I doubt they will cover bubbling.
Old Feb 5, 2012 | 08:32 PM
sLAsh's Avatar
My 07 is bubbling and peeling at the door bottom. Dealer says they won't cover it unless it rusts through
Old Feb 5, 2012 | 08:36 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Wash your car better in the winter time. Most definitely a Salt issue, since Michigan seems to think salt on the road should be like icing on a cake.
Old Feb 5, 2012 | 08:52 PM
C_A_D88's Avatar
Dealer paint warrenty is for perforation only,
So if u leave it long enough for it to rust a hole
Thru your door then they will cover it, surface rust they won't cover, there has to be a hole in the sheet metal for them to do anything
Old Feb 5, 2012 | 09:10 PM
Open that bitch up with a Dremel. Give it a month to rust up some more... take it in for warranty.
Old Feb 5, 2012 | 10:52 PM
insylem's Avatar
Rust warranty is only if it rusts completly through and there is a hole.
Old Feb 5, 2012 | 11:41 PM
bluebalt07's Avatar
Absolutely ingenious
Old Feb 7, 2012 | 11:14 AM
andywmu's Avatar
Might grab a quote from a body shop down here to catch it before any rust starts.
Hard to get a good wash on the car weekly when living at an apartment, really sucks!
Old Feb 8, 2012 | 09:07 AM
Run it through an automatic touchless car wash... make sure it has an underbody washer.
bigdeertz
Nov 17, 2016 09:41 AM
Oct 21, 2015 11:57 PM
Oct 20, 2015 09:56 PM
importkiller
Sep 30, 2015 07:18 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
