SC over boosting and whistle
Old Sep 16, 2015 | 09:36 AM
DevZX's Avatar
Hey guys so the other day in a first gear pull at around 5k rpms the car lost power for a split second then immediately afterwards started hitting boost with a slight tap of the gas with a whistling noise after about 12lbs... It hits about 15lbs now which used to only hit 12... I replaced both bypass valve and solenoid and it still does it. What could it be? BTW the car is gm stage 2 with zzp pcm... Thanks guys..
Old Sep 16, 2015 | 09:38 AM
Powell Race Parts's Avatar
suggest exhaust restriction
Old Sep 16, 2015 | 09:42 AM
DevZX's Avatar
Would it have come up so random like that if it was an exhaust restriction?
Old Sep 16, 2015 | 09:56 AM
07blackg5's Avatar
Slobodan Milošević
cat could have collapsed and plugged up
Staged07SS's Avatar
Administrator
Administrator
Check your cat if u have one. Could be clogged and causing the restriction.
Old Sep 16, 2015 | 10:00 AM
DevZX's Avatar
Hmm alright.. I know I have a cat but how do I check if its clogged? I've herd about going uphill in low gear if the car barley goes it could be clogged but I have no hills around me.. Lol
Old Sep 16, 2015 | 10:21 AM
Staged07SS's Avatar
Administrator
Administrator
Take the downpipe off and look inside.
Not hard to remove.
Old Sep 16, 2015 | 11:06 AM
DevZX's Avatar
Not hard to remove.
Previous owner welded the entire exhaust system together..lol..
Old Sep 16, 2015 | 11:08 AM
Dipped_Cobalt's Avatar
nothing a grinder cant cut apart or sawzall
Staged07SS's Avatar
Administrator
Administrator
Are u serious?? Ohh boy...
Old Sep 16, 2015 | 11:20 AM
im serious too lol
Old Sep 16, 2015 | 11:22 AM
DevZX's Avatar
Yeah I bought a catback and was about to put it on then saw the horror... I should look into a header/downpipe soon and cut that crap off.. Haha.. But also want to make sure its the problem first.. Don't want to mod it without fixing this big issue..
Old Sep 16, 2015 | 11:46 AM
Kolt's Avatar
or take out your o2 and use a boroscope or tiny mirror on a stick lol
Old Sep 16, 2015 | 06:19 PM
DevZX's Avatar
If it ends up not being an exhaust restriction what else could it possibly be?
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
tomj77
Oct 4, 2015 11:39 AM
717ssbalt
Oct 2, 2015 04:01 PM
