Service Traction/ Reduced Engine Power
I am having massive problems with my 07 Cobalt. I keep getting "Service Traction" error as well as reduced engine power. I had it loaded on a car hauler and brought it to a mechanic. The
mechanic told me that it is the crankshaft position trigger and the cost will be $1600 or more, due to the parts location. Which is located inside the engine block. I replaced the crankshaft position sensor yesterday but it didn't help any.
Any suggestions?
Any suggestions?
Any suggestions?
Any suggestions?
There are relatively cheap borescopes available online that you can use wirelessly with your smartphone. Alternatively, find someone who has a bore scope so you can remove the sensor and inspect the reluctor wheel as someone slowly rotates the engine. I'd think you should be able to see if it is bent or something happened to deform the notches. It's more work but you should also be able to inspect the wheel if you remove your oil pan. I'm pretty sure the whole crankshaft has to be removed to replace it but maybe if something is slightly bent or clogged up you can massage it back to place from underneath.
lightningbalt
Jan 26, 2011 12:08 AM
RedBaseBolt
May 2, 2007 07:29 AM
