so....ummmm....is this fixable??
Old 05-11-2008, 10:31 PM
my_bd's Avatar
Old 05-11-2008, 10:32 PM
originaladrian's Avatar
i would say no
Old 05-11-2008, 10:34 PM
StreetDreamz's Avatar
Nope. I got a similar one here:
This one happened
So I did this:
Then this happened:
Your diff is shot, buy a new tranny. That looks like a pin made it's way out of a spider.
Old 05-11-2008, 10:36 PM
bridfi's Avatar
wtf? how??
Old 05-11-2008, 10:39 PM
Too much powa son. No joke. GM FWD trannys always have and always will be.....weak.
Old 05-11-2008, 10:41 PM
bridfi's Avatar
looks like something exploded.
wow.
Old 05-11-2008, 10:42 PM
GULLABLE0NE's Avatar
daammmmnnnnn
Old 05-11-2008, 10:43 PM
WSFrazier's Avatar
The Hahn FWD Cavy/Sunfires are in the 500hp range running awesome times at the 1/4 with stock trannies. Have been for years.
IMO it's the driver. I've seen people do the same thing with stock cars. The people on here with 350whp+ have yet to nuke a trans.
Old 05-11-2008, 10:45 PM
Super_SS's Avatar
sort of looks similar to my first blown tranny...but mine had a much bigger hole.
Old 05-11-2008, 10:46 PM
I'm too JDM for you
BLAZIN07SS's Avatar
blackg85 had 411fwhp on stock clutch and tranny. the motor went before the tranny even flinched
Old 05-11-2008, 10:49 PM
Sharkey's Avatar
ill disagree. had a v6 cavalier before this car, i know a lot about and have built quite a few of the getrag 282 that were behind the 2.8 and 3.1, aswell as the quad 4 ho. i know of a few guys running 350hp and 400+ ft/lb through them with a v6. also there are a lot of fiero guys that run them with v8s and they stand up. they are a very beefy tranny. even the axles in that era hed 350+ hp without issues behind a v6. i have seen diff pin failures and its caused by driver error. basicly, dont spin the tires in your fwd and diffs dont break.
Old 05-11-2008, 10:58 PM
my_bd's Avatar
yeah, all of the gears and the clutch were still working fine before I pulled it apart cuz it was leaking fluid.
Looks like a bullet went through there.
Old 05-11-2008, 11:05 PM
If you know sooooo much about that tranny (and the Isuzu tranny for the later on Cavs) then you will know the output shafts warped left and right. Don't tell me they hold power fine. You go ahead and tell me that there's an easy way to drive your FWD car hard and not spin the tires.
I will beg to differ. I've gone through two trannys and two stock clutches at roughly that power level. And don't say it's the way I drive please, it shouldn't matter how it's driven. If it's going to handle it, it's going to handle it. If it's not, then it won't.
Old 05-11-2008, 11:51 PM
WSFrazier's Avatar
So there is no such thing as abuse? Lol...
Old 05-12-2008, 12:00 AM
INDColtsFan18's Avatar
thats not good, that would be a pretty big fix cost.
Old 05-12-2008, 12:15 AM
Pully Police's Avatar
So...according to you: If I drive "properly" (Aka: better then all the people with blown trannys) my tranny will have the same lifespan as if I drove it doing 6000 RPM clutch drops everytime I was in first gear?!?
Seriously.
Old 05-12-2008, 12:20 AM
my_bd's Avatar
I was expecting a trail of fluid coming from that hole, but there's nothing near it.
it's clean. weird.
Old 05-12-2008, 12:36 AM
LSX RWD S/C conversion
victory_red_SS's Avatar
How did you finally get the axle out???
Old 05-12-2008, 02:04 AM
Super_SS's Avatar
new tranny...u most likely fucked a gear up and ur diff took a crap...new case is about 1600 bux
Old 05-12-2008, 08:10 AM
Coblasts's Avatar
Welding the cast aluminum caused the other damage .(You over heated it and it warped most likely)
When Ive seen that stuff welded The guy would pre heat the casting or the whole area to destress it.
Otherwise the aluminum warps to badly when it cools to quickly.Its a characteristic of the cast aluminum.
Old 05-12-2008, 08:20 AM
2K5SS/SC?'s Avatar
Hmmmm.....It looks as though something had to break and smack the case from the inside to chip the housing like that. Mine broke in the same general area as everyone else's has, but I also had fragments sitting outside the case as well.
Good luck finding a another tranny or purchasing a new one. I have been in this situation twice before, so I know what it's like.
Old 05-12-2008, 10:31 AM
Seriously.
I said if the tranny is going to handle it, then it's going to handle it. If it's not, then it's not. It shouldn't matter how you drive it. If it's built well enough to handle the abuse then you won't have problems. I have a friend who's 03 Cobra LIVES at the track. He has put almost 30,000 miles on it just driving to and from the track and launching it at the track running 10s, also making around 700rwhp. His stock Tremec is still in tact 100%. I have gone through two trannys in about the same time span.....
Old 05-12-2008, 10:43 AM
my_bd's Avatar
well the friggen axle is still stuck inside the intermediate shaft, but I managed to finally coax the intermediate shaft out of the tranny.
So for now, the axle and shaft sit on the garage floor and I just give em the bird every time I walk by them. Not sure how to get them apart, or even if its worth the bother.
Old 05-12-2008, 10:56 AM
Rent me! per hour
Area47's Avatar
Seriously.
we had this talk. you can't aruge with the special people.
Squire33
07-30-2015 04:36 PM
Builttss
07-05-2015 03:56 PM
quad
11-01-2012 07:54 PM
m1ke495
07-19-2010 11:26 PM
Quick Reply: so....ummmm....is this fixable??
