Starter not engaging flywheel 2005 lsj
Old Mar 27, 2018 | 12:33 AM
Chanyeezy's Avatar
2005 cobalt ss. F23 transmission swap. So on this transmission swap the starter is not engaging the fly wheel. New starter, 12 volts to the starter, I even used a snap on torque wrench to set the specified torque and degrees. It's just not engaging onto the flywheel itself. Flywheel appears to be pretty close to the block looking in from the starter area. Spun the crank pulley and it spins. Gsts a little hard at a half a turn then breaks free, im assuming that would be due to the compression though. What could I have done wrong and what should I check before tearing it down again?
Old Mar 27, 2018 | 12:37 AM
Sharkey's Avatar
is the starter spinning and not engaging, or just doing nothing?
Old Mar 27, 2018 | 12:38 AM
Chanyeezy's Avatar
Starter is spinning and not engaging
Old Mar 27, 2018 | 12:51 AM
Sharkey's Avatar
what id do is remove the starter and test it with a pair of jumper cables. watch the gear and see if its being pushed out or not, this will tell you if you have a ring gear distance issue, or if the starter is no good.
my money is on the starter, more specifically the solenoid.
Old Mar 27, 2018 | 12:55 AM
Chanyeezy's Avatar
Starter was just purchased hours ago but I will try that, thanks
Old Mar 31, 2018 | 02:48 AM
Chanyeezy's Avatar
It was a bad ground thanks all
Old Sep 10, 2021 | 07:13 PM
Brandon E's Avatar
Cobalt ls starter
what ground was the issue? I am having the same problem
G85 SS
Dec 20, 2018 12:46 PM
06G85
Mar 19, 2010 07:39 PM
bri2203
Mar 24, 2009 09:38 AM
OffLightsEdge
Jan 30, 2009 01:22 PM
