Sturdier Fuel Pump?
Old Jul 22, 2020 | 01:46 PM
themusicguy1989's Avatar
Sturdier Fuel Pump?
So I just pulled my fuel tank. I had a broken fuel pump. The motor still works but the springs were in the bottom of the tank and the bottom half of the pump was just dangling in the tank. I just got this pump replaced 60,000 miles ago at a mechanic shop (they charged me $800 btw wtf!? Not a $800 job imo after pulling it myself). The original pump lasted 144,000 miles and that was after the motor actually burned out. I'm wondering if anyone makes a good sturdy fuel pump that I can buy so that this doesn't happen again. I've looked around but there are reviews to give me a good idea of how sturdy these pumps are.
Right now I'm looking at this one
https://www.carparts.com/details/Che.../AFE3807M.html
Or this one
https://www.carparts.com/details/Che...ACM100020.html
My vehicle isn't qualified for any recalls btw.
Old Jul 22, 2020 | 02:22 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Ouch. $800 is a lot for that job.
ACDelco is an OE supplier and is half the price of the other. IMO, that makes the choice easy.
If you want a higher volume pump, AEM and Walbro are both solid choices; not quite as "drop-in" as the OE package though.
Also, when are you refueling? 1/4 tank? E? Half-past E (aka fumes)? And are you filling the tank all the way? Seems silly, but I've seen people that will only put a quarter tank in, then run it down to fumes, and continually repeat that process. It's not good for the pump.
Old Jul 22, 2020 | 02:59 PM
I fill up it up every time and usually refuel at a quarter of tank.
Old Jul 22, 2020 | 03:11 PM
I'd imagine the 2nd fuel pump failure was just a cheap pump then. But, **** happens, and manufacturing isn't a perfect process.
Old Jul 22, 2020 | 04:03 PM
I second the cheap pump or a poor installation
Old Jul 27, 2020 | 10:08 AM
So I decided to post this just in case someone else has the same problem that I did. So this is where my fuel pump broke. The tubes that hold the guide rods broke, the spring popped out and the pump would not operate properly. So i bought a brand new AC Delco pump with the fuel level sensor from Rock Auto.
https://www.rockauto.com/en/moreinfo...44463&jsn=1007
That one^^^. Well on the brand new pump those same exact tubes that held the guide rods were already cracked all the way up to the base. You could see guide rods through it and could see how the plastic just separated, like the rods were too big to fit in them. So that pump would have also prematurely failed if I had not noticed it before installation. So I sent it back and went with this one.
https://www.rockauto.com/en/moreinfo...44463&jsn=1009
The last one they had in stock. Cost $384 without the fuel level sensor. Spectra Premium is a small private business based out of Canada. Fingers crossed that this fuel pump is of higher quality than the AC Delco pump. I will update once the pump gets here.
Also, I did not have the foresight to take a picture of the wires before I pulled the fuel level sender out of my old pump. It has 2 purple wires and I'm not sure which on goes into which side. Anyone have any advice? Hopefully the pump's instructions itself will explain this but it may not.
Old Jul 27, 2020 | 03:53 PM
Okay, you're not saying the fuel pump itself failed, but rather the pump housing assembly.
You honestly could probably just grab one out of a Cobalt in a junk yard and swap the actual fuel pump itself.
Old Jul 28, 2020 | 12:47 AM
Doesn't matter anymore. Someone just hit my car while it was parked and totaled it. Will be parting it out soon.
Old Jul 28, 2020 | 04:43 AM
blu3_v1p3r's Avatar
Well, that sucks. Sorry man,
Old Jul 28, 2020 | 09:46 AM
BlackielawlessSS's Avatar
That really sucks... I am sorry.
Old Jul 28, 2020 | 01:14 PM
Yep...Rip, put so much money into to just for this **** to happen. Hit in the rear while the rear was jacked up on stands. I doubt insurance is going to give me much for it. Everything behind the fans is undamaged in the engine bay. So I'm thinking parting it out will be my best option.
Old Jul 28, 2020 | 01:20 PM
Caused damage to my room mates Civic Si also. Can't even park safely anymore.
Old Jul 28, 2020 | 01:29 PM
damn man, drunk driver or a text and drive?
Old Jul 28, 2020 | 01:34 PM
Looks like their strut mount took a **** on them while they were flying down the street. So some idiot who speeds in residential areas and doesn't maintain their car.
Old Jul 28, 2020 | 01:41 PM
Definitely getting that sound system out of there. My WRX speakers are complete **** compared to the Cobalt's.
Corrinaannajo
Nov 19, 2017 05:19 PM
pykie
Feb 21, 2011 05:50 PM
BlackCobalt707
Feb 7, 2011 11:01 AM
StreetDreamz
Mar 21, 2008 09:27 PM
jimbos'ss
40
Mar 14, 2008 02:00 AM
