Switchbacks problem
Old Oct 6, 2012 | 10:30 PM
CobaltItaliano's Avatar
Switchbacks problem
Bought switchbacks from Mike and I'm having problems getting the hyperflash to go away. I have the correct resistors and everything and followed his how-to:
https://www.cobaltss.net/forums/how-...isters-276188/
I have an 07 btw. I tapped into the blue wire and the black wire just like in his how-to, but still hyperflash?
Messed around with the other wires coming from blinker bulb (theres a total of 3 (1 blue, 1 black, 1 brown) and tapped into every wire combo I could have from that group and they still hyperflashed.
NOW, I did only my drivers side at the time, with the other side being the stock bulb. Does that matter? I also have k2 motor led tails, but had them done a while ago with resistors and never hyperflashed on me (they do now obviously cuz of the switchbacks).
Anybody have ideas?
Old Oct 6, 2012 | 10:31 PM
TommyP's Avatar
AWD > FWD
Make sure they taps are making a solid connection. Assuming you're using those blue taps, I've had bad luck with them in the past.
Old Oct 6, 2012 | 10:33 PM
What I was thinking too. When I took the connects off the wire the insulation seemed to be broken though
Old Oct 6, 2012 | 10:48 PM
serega12's Avatar
Use ”T-taps”... They work best. You can pick them up in your local Radio Shack.
Also, you have a resistor in each corner, right?
Old Oct 6, 2012 | 10:51 PM
Sir_Hiro's Avatar
Dont use T Taps..if you know how to solder..that way you have a 100% true Connection.
Old Oct 6, 2012 | 10:54 PM
Not sure what you mean by resistor in each corner? I have the 2 resistors in the rear for the tails...worked fine before installing the switchbacks, no hyperflash.
I installed the driver side switchback just like in the how-to and it hyperflashed. I had the passenger side stock bulb in at the time.
Really don't want to solder just in case I ever need to remove them its a bit trickier and more time consuming.
Last edited by CobaltItaliano; Oct 6, 2012 at 10:54 PM. Reason: Automerged Doublepost
Old Oct 6, 2012 | 11:14 PM
It doesn't matter if the stock bulb is still in the other headlight, that won't affect the hyperflash.
If you tapped the blue from the blinker and the black from the stock harness you shouldn't have hyperflash. I believe the stock harness has a brown wire that looks like a black one if I remember right, make sure you didn't tap into it by accident instead of the black.
Other than that just make sure you have a good connection like Tommy said. I used T-taps.
If you still have hyperflash then I'd say the resistor is bad, try the other you have to see if it works.
Old Oct 7, 2012 | 12:47 AM
Sir_Hiro's Avatar
if you have a voltmeter check the Resistors..
Old Oct 7, 2012 | 12:56 AM
Thnx guys. Yea im gunna check the resistors with a volt meter and see if their good. Yea I tried both resistors with the drivers side and still had hyperflash. If the resistors are good after I check them out i'll just get different wire taps. These the ones you used:? Wire Tap-In Squeeze Connectors (7-Pack) : Connectors | RadioShack.com
Old Oct 7, 2012 | 02:05 AM
reaper89's Avatar
i have those squeeze type connectors that i bought from him also, and they work perfect.
Old Oct 7, 2012 | 02:16 AM
juan1101's Avatar
Did u strip the wires
Old Oct 11, 2012 | 06:50 PM
picked up 2 different wire taps at radioshack today. One is a 18-14 gauge connect (the blue) and the other is a 22-18 gauge (red/pink) Which should I use?
Old Oct 11, 2012 | 07:44 PM
Red
Old Oct 11, 2012 | 08:39 PM
yea used the red ones. Seem to be working alright now. Had to squeeze the drivers side tighter after it must've lossened a bit after I put the headlight back in place so we'll c how they hold up. Really nice to not have hyperflash now lol
Old Oct 11, 2012 | 09:21 PM
Glad you got it fixed and yeah I hate hyperflash lol
Old Oct 14, 2012 | 11:26 AM
serega12's Avatar
I had to put a resistor at each one of four turn signals (two front and two back)... Not sure why, they were big enough to run both... probably has something to do with ECM controlling each individual turn signal, not just a load across each side.
Old Oct 14, 2012 | 11:31 AM
serega12's Avatar
That.
That's what I meant but them working best. Easily reversible. If your resistor is mounted with a bracket to the body of the car, you don't have to unbolt that every time you remove the headlight (for the bulb, to replace fog lights, etc), you can just unplug the t-taps.
And if you think that crimped connections are bad - every connection coming to the ECU/fuse box/switch is crimped. Works just as well if done right and is removable. Yes, with soldering you get a solid connection, but it's a PITA (gotta cut and tape over every time you have to modify or return to stock)
Old Oct 14, 2012 | 11:47 AM
serega12's Avatar
I went with a different type:
Quick Splice Connector with Male Disconnector (3-Pack) : Disconnectors | RadioShack.com
Once they're on, they become a true removable/disconnect-able T-tap connection.
It was suggested by one of experienced installers for anything that might need to be reversed. I used blue on mine with no issues.
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
