Tranny Whining on decel
Hi all......
I've noticed that when slowing down in gear(1st-3rd) the transmission now makes a whining noise??? Is this normal??
'06 SS/SC
Banzai !!!!!!!!!!!1
'06 SS/SC
Banzai !!!!!!!!!!!1
The Cobalt does have some gear whine, which is totally fine in a lot of cars. I notice it mainly when I get off the freeway and I'm coasting down in 5th, but it's pretty much always there. It shouldn't be too loud - if it's intrusive, I'd get it checked, but otherwise nothing to worry about.
Its normal i've had it happen in every manual i've ever driven and did notice it a little more in the cobalt the other day, but maybe its the colder weather, but my bro's 91 MR2 does it, My moms miata does it and so does our 94 4 runner so its normal
From: Ellsworth AFB, South Dakota (from Mechanicsburg, Pennsylvania)
Mine does it too. It didn't do it much at first but got a little louder once I put a couple thousand miles on it. Now it's settled in and hasn't gotten much louder at all.
Originally Posted by 06blackg85ss
check your fluid levels... mine did that and I discovered I was 1/2 qt low on fluid (I forgot to add when I swapped axles).. went away though... did it mainly when it was cold
I've notcied it gets louder as its colder. Noticed it tonight, but it happens as I have the clutch in and am coating down. Must be a synchro thing...
Originally Posted by BanzaiSS
Hi all......
'06 SS/SC
Banzai !!!!!!!!!!!1
'06 SS/SC
Banzai !!!!!!!!!!!1
Thanks All!!!
This'll save me a trip to the service dept.
Does the tranny have fill and drain plugs
I don't have a service manual and I forgot to look while I was changing the engine oil.
Does the tranny use Syncromesh?
Unfortuneatly, I might have to take it in anyway due to clunking while letting the clutch out. They checked it out once............ it seems to be getting worse.
I'll change the fluid before taking it in though...........can't hurt.
Banzai !!!!!!!!!!!!!!!
Sean Cummings
Mar 9, 2018 12:26 AM
Iceberg
Sep 29, 2015 12:33 PM
