wot pull then died....
hi i just got an 06 cobalt ss/sc and decided to do a wot pull 1st gear (wheel hopped bad) then the car just died and wouldnt start for about 5min (would crank but thats it) then it started shows a cel but runs fine. now (idk if its always been there) but i hear a noise kinda like ticking sounds like its coming from the supercharger...its not as loud as the videos of bad timing tensioners i found on youtube nor does it seem to be coming from the same place....i also have a weird aroma idk if its clutch or brakes (brakes are bad). oh and a one time recently i floored it and it wouldnt rev past 3k or so then it would just randomly work again...any ideas?????
everything happened at once and then wouldnt rev past like 3k thing went away so thats why i went to do it again to see if it would continue but instead it just died. and the brakes are bad yes but they def stop the car fine and its not like i cant stop whenever. but i am replacing tomorrow and i will run code
lol just got the car 2 days ago had 0 problems have floored it a total of 5 times or so (just bought it so of course i wanted to have some fun) cel is now gone and im almost positive the smell is my brake caliper hanging up because the car pulls to the left while driving (tires pressure is fine lol) so we shall see. im going to clean the throttle body and see what that does as well
alright the sound seems to be something similar to bearings, it gets louder as i rev. it sounds like its coming from my supercharger? is that normal or should i fix it asap?
you guys act like i knew it had these problems i had no idea....now that i do i can assure you i will no longer be doing any wot pulls any time soon until problems are solved.
Sounds like half the people "helping" this guy are just fucken dicks. He said he just bought the damn thing and has floored it only a few times. And noticed some issues. Give the guy a break and help.
Dont lie we have all been their, we have all had a car that we would beat on over and over until it died completely. But the older wiser me says yes fix your **** b4 you keep beating on it
i am fixing it . and i will admit my last car (1991 mustang lx) i floored it every day none stop with never even 1 problem so i went into the cobalt thinking i could do the same, obviously isnt the case lol i now know. anyways seems to be running great now onlything that im doing now is cleaning the tb just incase and rotors, brakes, calipers today
When you buy a brand new (used) car and you think you notice a provlem, but your not sure what it is. Obvioisly you are going to test and try to re-creat it to narrow it down. Not everyone that buys a new car can tell, oh THAT clicking sound is a lifter and not a timing chain, or a wheel bearing to a stuck caliper.
Cels dont tell you everything, and a fresh new car is.. Wel just that
All vehicles act different snd he went from a 22 year old ford to a newer chevy s/c
alright the caliper wasnt sticking luckily. the smell was from my brakes and warped rotors. cel is gone car is fixed completely from what i can tell....um just incase someone has the same issues i had with the car randomly dieing, i had just installed a injen cai and i didnt unplug the negative battery cuz im lazy lol anyways i unplugged it for 15 min (like it says) and now its fine idk if this was the problem but oh well its fixed. and from what i have read the bearing noise is fine for now.
They ask you to unplug the negative so you dont shock your dumb ass installing it
The "bearing" sound you were hearing was probably the ******* supercharger once you put the intake on
garret...no the noise isnt from installing the CAI, and i thought unplugging the negative battery reset the ecu and it would recognize the new air flow coming in and adjust to it. if thats not the case then my bad but the bearing noise is clearly not normal. oh well
