Rebel Auto Worxs Rebel Auto Worxs is a proud Supporting Vendro of CobaltSS.net.
Contacts: Eng@RebelAutoWorxs, Sales@rebelautoworxs, Tech@RebelAutoWorxs
RAW intake causing the P0171 code?
Old Jun 11, 2008 | 11:11 AM
RedEcotecSS's Avatar
Just installed the RAW 3" CAI and now I am throwing this code. If you read in the problems and service section of this forum, you'll see a sticky on the P0171 CEL. It states the following:
This CEL is set also when the LTFT is above 20% in any of the trim cells. Usually it means your MAF isn't registering all the air passing by it, either you have a leak or the intake messed up the air flow enough so the MAF isn't registering all the air passing by, like oil on the maf, ect.
Does this sound like anything that can be caused by the intake?? Just wondering....
Old Jun 11, 2008 | 11:16 AM
Omega_5's Avatar
I've never heard of any RAW intakes throwing that code.... although it is very possible.
I'd be willing to bet, that one of the pipes wasn't fully seated into the coupler, and it's pulling non-metered air.
Old Jun 11, 2008 | 11:19 AM
M-Dub's Avatar
Yes... 05 and 06 models have an issue with intakes... I threw that code myself.... it has sence been fixed with tuning!
Old Jun 11, 2008 | 11:24 AM
How is it fixed with tuning? Did you just disable the code?
Old Jun 11, 2008 | 11:31 AM
nhanson's Avatar
well i would make sure everything is together correctly...then unplug the battery to reset the pcm....
Old Jun 11, 2008 | 11:36 AM
Could this code cause any engine problems or anything?
Old Jun 14, 2008 | 12:12 AM
Eng@RebelAutoWorxs's Avatar
as mentioned we have never had any of our intakes throw a code.
I would check all your connections first, you can also spray some brake cleaner around the intake to see if you have a leak. If the car bogs, you have a leak.
LTFT being off isn't anything new with installing aftermarket components. Basically the car thinks things are off (more air flow) and wants to adjust. It basically compares your maf reading to what it's getting through the narrow band o2 sensor. It will not affect anything as your narrow band will do the adjusting, just means your car won't be as smooth regular driving.
A tune will fix this.
With any new components a tune is always recommended, complimented with a A/F gauge.
turbochargedss2012
Sep 20, 2023 12:17 PM
DarrenGC
Dec 24, 2021 01:55 PM
ernnyyes
Oct 2, 2015 05:16 PM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
