Rev It Up Motorsports Rev It Up is a proud Supporting Vendor
NEW PRODUCT Revitup Motorsports Boost Upgrade
Old Jan 4, 2006 | 05:55 PM
TxLonghorn#1's Avatar
Originally Posted by bdwarr6
I got my stage 3 kit put on friday.
Since then I have opened her up quiet a few times, used 4 tanks of gas. At WOT she is a beast, plain and simple. I walked 2 stage 1 srt4's with ease. I walked a 12 sec gtp not off the start but once i hit 3rd gear i pulled increadably hard on him. SOme Honda that was putting 260 to the ground i walked by 3 cars.
I boost 12-13psi at about 1/3rd throttle 15 at half and 17-18 at full.
My Modicifations
Injen Cold Air Intake
INTENSE modular supercharger hub with 2.80” pulley
Lucas 42.5 pound/hour fuel injectors
Casper’s fuel injector connectors
MAF Translator
Autolite 3922 spark plugs
I am also running rich till I get to the dyno this week.
I also was playing with a c5 corvette but a cop intervened in that one before we could determine a winner.
With all the mods that "bdwarr6" has from Intense for $507 shipped, why would you just sale two tuned pullies for $500? Is there anything else available...maybe injectors? I was just wondering?
Old Jan 4, 2006 | 06:14 PM
turboeco's Avatar
I have the very first Psi-Fi kit installed on an SS. This was before Psi-Fi released it to the public, so I have there old wiring method and tune.
I remember hearing when you got ahold of the powerpack, you showed them how to rewire/retune, so they wouldn't get air intake codes anymore. You also got some more timing out of it.
My question is, can I come to your shop and have you check my wiring, and flash me with your latest CEL free tune? If so how much?
Thanks a lot!!!
Old Jan 4, 2006 | 06:16 PM
06black's Avatar
RAY-----will this kit work with a smaller pully?? or is it just for the 2.8....also does the car run lean with the smaller pully and the stock injecters?
Old Jan 4, 2006 | 06:31 PM
pclear9061's Avatar
just wondering but why would you want smaller than 2.8? smaller is just gonna make you loose power........
Old Jan 5, 2006 | 09:10 AM
ray@revitup's Avatar
it comes pretuned for a 2.8 pulley. you can the retune it for what ever you want
Old Jan 5, 2006 | 09:29 AM
R33P3R007's Avatar
360 L337 User
when are you gonna have another shop get together. we need to talk business.
Old Jan 5, 2006 | 09:38 AM
ok 1st of all i hate the whole vendor fights that go on on srtforums and i hope not to have any here. but here is why our kit is more.
there kit comes with a maf translator a maf translator retails for about 179.99 and here is what it does. it scales the Mass Air Flow frequency reading to the PCM allowing you to control fuel up or down. This is necessary when using injectors that are larger or smaller than stock or when trying to change air/fuel ratios without PCM access.
our kit comes with a complete piggyback system which via a laptop you can control afr's by also scaling fuel up or down. you can also monitor where you have to make corrections on a realtime screen. plus if you decide to go with a larger injector it will also allow you to do so. our piggyback controller alone retails for 389.00
The piggyback we provide also gives the owner the option of running secondary injectors.
Feature Benefit
Throttle Sensor learning feature - already calibrated for the lsj ecotec
RPM Calibration - already pre calibrated for the lsj ecotec
Fuel map with 128 sites - allows full control of the afr's
Ignition Map with 128 sites - allows ignition timing to be retarded under high boost
Injection Map with 128 sites- For extra (boost!) injection. fully mappable control of nitrous, water injection kits
0 - 10 volt analogue range Allows tuning of all models- sell the lsj ecotec, install it in your new car.
6 Amp injector drive- Handles 6 x 16 ohm injectors
Ignition output limit- Limits max. advance and retard
Fuel High low limit -Prevents overdriving the ECU
Small Size Fits -Anywhere
Map Switchable While you drive switc from a race tune on race fuel to a street tune.
All Inputs Protected- No mishaps!
Crystal Controlled- For Stability
Encapsulated For Moisture and Dust
Easy Tuning Software DOS or WINDOWS
10 MIPS computing -To facilitate quick engine response
Signal Conditioning- To prevent miss trigger
Engine profiles (library) -Easy set up
Lambda Signal -Tuning Modification of Lambda Senor Readings
Proportional Nitrous Control Less waste of power in nitrous injection
and more
Old Jan 5, 2006 | 09:45 AM
come down tommorow night, just not at 11 pm though try earlier
Old Jan 5, 2006 | 09:48 AM
Feature Benefit
and more
our system basically has more expandability. from what i have seen there stuff works great and we have installed some of their systems for other gm vehicles. if someone buys there system and which to have us install it we will be glad to do so aswell.
Old Jan 5, 2006 | 09:50 AM
R33P3R007's Avatar
360 L337 User
sounds good... I have not decided what I am going to do. so If i go with Intense I can have you guys install it also. Thats cool since there isn't really anywhere else near us. OK, I'll try and stop down tommorow night. Before 11pm. I can't help I am a night person. And you guys were there lol
Old Jan 5, 2006 | 10:42 AM
  #36
gforce477's Avatar
A few questions Ray. Without using new injectors how maxxed out are the stock ones? Also where does the power difference come from then if you are both running a 2.8 pulley, I have seen several intense kits dynoing at around 270whp on the redline forums, what accounts for the apx. 25 whp difference. Also the kit with the software is only 525 shipped then? And last is it possibly to run larger injectors by using the piggyback.
Thanks a lot Ray
Old Jan 5, 2006 | 11:29 AM
  #37
Bad06SS's Avatar
Hello. How are you getting the fueling right without adding injectors with your kit? I've seen dyno sheets with 3.0" pullies where they're totaly lean. I know fast06SS, he said his injectors were well over 100% duty cycle with a 3.0" pulley. In fact it's funny, with the GM stage kits-they give you injectors before they even give you a smaller pulley. Not trying to vendor bash in any way, but the kit doesn't seem to fix all the problems at hand when dropping pullies. I'm afraid of chipping pistons.
Thanks for any insight.
Old Jan 5, 2006 | 11:31 AM
  #38
R33P3R007's Avatar
360 L337 User
good question
Old Jan 5, 2006 | 11:54 AM
  #39
we are adding fuel via the ecu. injector duty cycles are in the 89% range at redline. we have enough injector and tune for for a 2.8 pulley. if you deide to do a smaller pulley than a 2.8 then all that you would have to do is buy injectors and retune the map. i would also like to see a baseline dyno of the cars that dynoed 275. my wifes car made 196 whp stock and 242 whp with our kit.
Old Jan 5, 2006 | 11:56 AM
  #40
Thanks a lot Ray
you can run larger injectors but you dont need them with a 2.8 pulley. if you go to a smaller pulley then its a different story. then you will deffinatley need injectors.
Old Jan 5, 2006 | 01:52 PM
  #41
turboeco's Avatar
Ray, any chance you could answer my question above, or the PM I sent you?
Thanks a lot!
-Travis
Old Jan 5, 2006 | 02:04 PM
  #42
y2kzman's Avatar
I'm in the same boat as Turboeco. Is recalibrating our units a possibility.
Old Jan 5, 2006 | 02:06 PM
  #43
R33P3R007's Avatar
360 L337 User
I am sure he could do that for you.
Old Jan 5, 2006 | 02:10 PM
  #44
06black's Avatar
why am i going to lose power with a smaller pully? if i go to a 2.65 or 2.7 than i increase boot...makeing more power not less
Old Jan 5, 2006 | 02:12 PM
  #45
R33P3R007's Avatar
360 L337 User
i don't get that either.
Old Jan 5, 2006 | 02:18 PM
  #46
max_boost's Avatar
Once you get the blower out of its effeciency range all spinning it faster is going to do is make extra heat. I'm not sure that point is 2.8 but it probably is pretty close.
Old Jan 5, 2006 | 02:27 PM
  #47
06black's Avatar
from what i info i've got from my GM and eaton buddys you can run as small as a 2.6 or maybe even a lil smaller on the m62 with the lsj moter...so i think i'm in the clear.
Old Jan 5, 2006 | 02:31 PM
  #48
06black's Avatar
Feature Benefit
and more
ok so i'm not as smart as i thought after reading that!
is the redline adjustable at all? and is the tuneing something we can do or learn to do...or is it something i'm going to have to have a shop do???
great work ray this sounds awesome! i think by the sounds of this your kit and the intence kit schould put down the same numbers....am i rite?
Old Jan 5, 2006 | 02:57 PM
  #49
cvenom2122's Avatar
Thumbs up
I just want to know what they have such different numbers? there is a little difference between the kits but that is all. I would buy the Rev it Up kit if it mad 260 whp like the intense! Rey do you have and intake, or exhaust on the SS if so what were the numbers after words!
Old Jan 5, 2006 | 03:03 PM
  #50
max_boost's Avatar
I think you've got to look at more than just the whp number. Hell your brother's car dynoed 250whp and do you think it is faster than a car with Ray's kit, I doubt it.
Revitup dynoed 196 whp stock and 242 with the kit. A peak gain of 46 hp. The car with the Intense kit dynoed 230 whp stock and 270 with the kit. A peak gain of 40 hp. I'd say that the two kits are pretty much equal in how much power they add.
