Weld splatter on muffler causing rust!
Well when I had my tip welded to my muffler It had some weld splatter on the front of the muffler. Now those areas are causing rust spots and looks pretty cheap/ugly in my opinion. Has anyone had this happen to them and tried to remove said spots? and if you did how did you do it? I heard steel wool maybe or some fine grit sand paper? Wouldn't this scratch the muffler though? just looking for some input! heres a an example pic.
A good rubbing compound may work... hell even steel wool.
Personally, id just polish it and make it shine. Usually 3000 grit and some good metal polish will work.
Maybe remove the rust spots and paint it?
