New powell xd seat brackets
these brackets are designed to work for aftermarket seats. stock seats have a fairly elaborate structure underneath to faciliate up, down forward and back adjustment plus recline, so that means higher installed height.
aftermarket seats just go forward and back and recline if its built into the seat. I have not looked at reverse engineering the bracket to fit a stock seat, anything is possible, not sure that its worth it, unless you are very tall and dont care about the up/down feature, etc.
email me john@powellraceshop.com on Monday with your needs/wants and I will see what can be done
Just want to let everyone know, i just ordered a set of brackets from john. Cant wait to get them i have some sparco r100's ready to install.
John stayed up til the crack of dawn to put together a how-to, i appreciate that to the fullest.
Thanks to john and gloria for all of their great customer service.
Powell FTW!!!
Powell FTW!!!
Powell FTW!!!
Powell FTW!!!
Hey john, the only typo i found in the how - to is this:
On Page 12 :
"The exception is the single bar that has a 90 degree end on it to mount the inside seat belt latch mechanism. It is sandwiched between the Sparco slider and the Powell main bracket, with the 90 degree bed facing upwards. "
On Page 14:
"In this picture above, the seat belt plate is mounted, sandwiched between the Sparco slider and the seat, and the seat belt latch installed"
The correct order is on Page 14 correct ?
- My Screw holes on my Seats accepted the M8x1.25 Screws without a problem (no tap needed) guess i got a good batch.
- Torque Specs for Install:
All (8) 8M x 1.25 Screws 15 ft. lbs
(2) Bolts - Seat Bracket to Floor ???
(1) Seat Belt - Buckle Bolt (re-use stock bolt) 33 ft. lbs
On Page 12 :
On Page 14:
On Page 12 :
On Page 14:
(2) Bolts - Seat Bracket to Floor 37 FT LBS (50 N/MM)
On Page 12 :
On Page 14:
got my Powell xd brackets .... and installed my R100
installed this bad boy, other one is on back order.
(look closely, and you will see the Powell Harness Bar
1 down, 1 to go
The only issues i ran into were:
- The one bolt hole in the bracket did not line up with the hole in the floor board, I had to file the hole so it was oblong, fits like a glove now.
- I thought that the seat would be lower than the stock one (im 6' 4) but it seems to be the same height, so ill have to cram the helmet in here.
but all in all, seat is amazing & a HUGE thanks to Powell for all of the help/support and another fantastic product
1 down, 1 to go
okay sounds good, looking to get these by spring! already have the harness bar just need to order the seats and brackets ! how much did you pay for the seats and where did you get them from?
PM THMotorsports, they hooked me up.
Make sure you ask them for the Sparco Sliders as well.
Seats - $310 Shipped /each
Sliders - $75 shipped/each
XD Brackets - $380 shipped/pair
Total : $1,150
