New Product @ TTR - Turbo Tech Racing STOP Transmission Mounts!
We use a specific center bushing pin size, very precise to the actualy diamter of the bolt, which travels through it.
Over all JUST like springs, they must fit in a very specific, pre determined area/window. You could say ours look a lot like the factory ones, just made from aluminum?
Along with many other mount choices out there.Springs have 3 over all varables, spring rate, ride height and color... Basic principles of what springs are.
We use poly bushings at a specific durameter (hardness) for this application.
OUR customers asked us Turbo Tech Racing to manufacture these mounts, we did just that for OUR customers. They wanted an axle alignment mount, in which was designed with poly, for a rigid mount setup, made with billet aluminum, and be a direct bolt in, did not want a mount they had to take apart and install an insert into. Like any good company would do, we listen and offered our customers with their request.
Thanks Nick!
Last edited by TurboTechRacing; Nov 2, 2009 at 10:29 AM. Reason: Automerged Doublepost
Perhaps I'm not informed well enough, but here goes anyway...
OK, I know this is for the F35 manual...I saw that you are hoping to have a 2.2 version out sometime near spring...will this only be for manual or is there an auto version in the works? Or is this something that doesn't work with auto's at all?
Thanks.
Mike
Thanks.
Mike
Thanks.
Mike
Thanks.
Mike
