Allignment on lowered car
Old Feb 4, 2010 | 01:42 PM
  #76
stretch89's Avatar
OP how are you liking the sportlines?
Old Feb 4, 2010 | 01:55 PM
  #77
yel-low's Avatar
did they give you a print out of the specs of the alignment before and after because the 3 i have done i had to adjust the front camber slightly
Old Feb 4, 2010 | 03:31 PM
  #78
_UnLiMiTeD_'s Avatar
Ye they gave me a print out, I'll check it when I get home.
Sportlines are great so far, a lot less body roll
Old Feb 4, 2010 | 03:40 PM
  #79
Cefaln452's Avatar
is everyone needing a camber kit?
Old Feb 4, 2010 | 07:56 PM
  #80
yel-low's Avatar
can u upload that to as a pic i would like to see it i do alignments for the chevy dealership i work at and other work to
Old Feb 4, 2010 | 08:30 PM
  #81
Boosted_Cobalt09's Avatar
Originally Posted by qwikredline
tutrunrtt777 is 100% correct. This stuff is no better than mild steel pos sway bars. Here is a piktar of a tenzo spring. UGH.
hello coil bind
Old Feb 4, 2010 | 10:20 PM
  #82
Here is the report sheet. Dunno why it comes up as 06 cobalt FE1 but the car drives straight, so i dont care lol.
Old Feb 4, 2010 | 10:54 PM
  #83
qwikredline's Avatar
hmmmm
interesting
Old Feb 4, 2010 | 11:27 PM
  #84
tru2nrtt777's Avatar
Originally Posted by Boosted_Cobalt09
hello coil bind
That is all they are good for.
Old Feb 4, 2010 | 11:52 PM
  #85
i just installed my steering rack spacers today and the car feels better, still pulls slightly
need to get another alignment i suppose
im on sportlines too, do u want to see my spec sheet too? of before and after
they recommend it after the alignment for me
i dont think its needed
Old Feb 5, 2010 | 12:33 AM
  #86
hmmmm
interesting
... how so?
Old Feb 5, 2010 | 01:14 AM
  #87
Noone needs a "camber kit" unless you are doing more than a 3" drop.
Old Feb 5, 2010 | 04:24 AM
  #88
87gn06gto07irl's Avatar
There is one thing I noticed that I thought I would mention. If I park and pull the parkin break, u can feel it lean on the rear suspension, which I know is normal, BUT that's also when the rear end suspension becomes uneven, if I park and don't pull the parking break the suspension is even, if I park and do apply the brake, the drivers side drops more then the passenger. It's probaly always done this but I haven't paid attention to it until I got lowered.
Am I being paranoid? Lol
Your fine. One side is grabbing more than the other making it lean.
Old Feb 5, 2010 | 07:53 AM
  #89
yel-low's Avatar
what year is your car is it an 06 or what because the specs are different
here ar ethe specs
xTooltipElement
Service Information
2006 Chevrolet Cobalt | Cobalt, Pursuit (VIN A) Service Manual | Suspension | Wheel Alignment | Specifications | Document ID: 879951
Wheel Alignment Specifications
Camber
Camber Cross
Caster
Caster Cross
Total Toe
Steering Wheel Angle
Thrust Angle
FE1
Front
-1.00° ą 0.75°
0.00ą 0.75°
3.00° ą 0.75°
0.00ą 0.75°
0.20° ą 0.20°
0.00° ą 3.50°
Rear
-0.80° ą 0.75°
0.25° ą 0.30°
0.00° ą 0.30°
FE3 and FE5
Front
-1.05° ą 0.75°
0.00ą 0.75
3.65° ą 0.75°
0.00ą 0.75
0.20° ą 0.20°
0.00° ą 3.50°
Rear
-0.80° ą 0.75°
0.25° ą 0.30°
0.00° ą 0.30°
Š 2010 General Motors. All rights reserved.
Old Feb 5, 2010 | 10:17 AM
  #90
Mines an 07 ss/na with fe3. As u can see on the sheet they didn't keep it within the fe1 specs and the car drives great so they seem to know what they're doing. They do a test drive before and after
Old Mar 30, 2010 | 02:59 PM
  #91
06cobalt racer's Avatar
if the top spring plate is notput back correctly, tab in, the ride height wont be the same side to side and the car will pull one way or the other....faulty installation is my bet assuming correct tire pressures alignment etc....
can you show a pic of what you mean by this? where is the tab? were you talking about the front or rear? the diagram that was posted was of the front struts right?
Turbo Johnny
Feb 21, 2019 09:41 AM
Haily229
Sep 17, 2015 07:18 AM
chris88z24
Sep 8, 2015 01:55 PM
Josh@ottp
Sep 8, 2015 10:18 AM
