Ball Joint Removable Tool
Old Apr 26, 2010 | 11:37 AM
Wangspeed's Avatar
Originally Posted by northvibe
so for a normal install you are suppose to hone the metal lca where the bushing is installed right? then the derlin should push in with hands and the metal shaft should push in as well? like no press or hammer needed?
No, don't mess with the control arms. Just get the delrin bushings in there, and then hone the delrin afterwards.
Old Apr 26, 2010 | 11:43 AM
Cobaltsky05's Avatar
its so simple....
take the nilock nut that holds it in place and thread it back on a couple turns then hit the head of the nut only so you don't damage any threads on the bolt with a dead blow hammer and it will pop right out. That's what I have always done and it's cake every time
Old Apr 26, 2010 | 11:48 AM
northvibe's Avatar
pff i totally missed the post by john...ugh my bad
Old Apr 26, 2010 | 04:16 PM
scottherbert's Avatar
No! Don't do anything to the aluminum. Get the delrin in -- and it will probably take a rubber mallet at least. Then open up the delrin to make the cross shaft fit easily.
I couldn't find a 1" reamer at any store in my area and I couldn't get a 1" drill without buying an entire big drill bit package -- and then there's the matter of a drill big enough for the 1" drill bit.
So I used a $19 wheel cylinder tool (three 220 grit stones) attached to my trusty power drill, and worked at it until I got the perfect fit. It probably isn't the fastest way, but it works just fine (I actully ended up buying two wheel cylinder tools).
Scott
This is the correct answer.
Scott
Originally Posted by Cobaltsky05
its so simple....
I didn't even need a hammer on mine, I just wiggled the bolt and the ball joint and it came out - almost forgot, I also took a chisel, pressed it into the gap (I didn't hit it or anything) and pried it open a tiny bit.
Scott
Last edited by scottherbert; Apr 26, 2010 at 04:16 PM. Reason: Automerged Doublepost
Solaris99
28
Mar 15, 2017 01:22 PM
biniecki
Oct 25, 2015 02:23 PM
Oct 20, 2015 09:56 PM
Oct 13, 2015 09:32 PM
