Best option for 2.2 handling
Old Aug 28, 2008 | 01:44 PM
  #51
montecarloman's Avatar
Originally Posted by Sentry
What would you suggest for an lt model? I like the low appearance of the sportline springs, but I do live in Texas, and the roads are not always habitable even for normal suspensions.
You think the SSC or the pro kit springs would be better? Basically I'm a bit sick of the 3" wheel gap I have right now.
Pro kit or SSC springs are probably a better choice for you then. Levels the car as opposed to lowering it and you get progessive spring rate instead of the factory linear which will sitffin things up nicely.
Originally Posted by IonNinja
Rear sway bar and front sway bar endlinks make the biggest difference IMO cornering wise...both are highly recommended.
Originally Posted by joeworkstoohard
what rear sway bar?
The rear trailing arm has an intergal "swaybar" welded into place. While its not a true sway bar it preforms the same function by stiffining the whole trailing arm.
Old Aug 28, 2008 | 04:54 PM
  #52
RyanRacer48's Avatar
OK you've sparked an interesting question I now have. Being that the suspension is mostly swappable between models.
Could I hypothetically move the entire Front braking system from an ss/sc to my LS? I've only gotten as deep as doing rotors pads and calipers so a conversion would be a first for me. Since I have 17's on my LS and the fact that I drive like a douce bag, I EAT through brakes.
Also dont they have adapters to put 5 lug wheels on 4 lug setup?
Old Aug 28, 2008 | 04:59 PM
  #53
Halfcent's Avatar
I'm old school
You can do this if you also swap on the FE5 knuckles, which will include the 5 lug hubs. But now you are opening a bigger can or worms. After all that expense and trouble, you might find it easier to use the SSBC setup.
patooyee
Oct 15, 2015 05:11 PM
Tupp
Sep 30, 2015 08:18 PM
importkiller
Sep 30, 2015 07:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
