coil spring issue
Old Jun 4, 2013 | 06:06 PM
mitchk90's Avatar
coil spring issue
My car's springs where cut before I got the car. And now they(front drivers) are making a noise over bumps, and when you turn the wheel. I can move the coil spring if I jack it up by hand. The plastic insulators on the bottom are done on both sides. Is this the issue of the noise?
Old Jun 4, 2013 | 06:09 PM
Sox-Fan's Avatar
Got Brakes?
Let's see.... Springs can move...noise isolators shot.... metal on metal....
Do I need to keep going?
Check the usual suspects too, end links, lower ball joint, control arm bushings, but start there.
Old Jun 4, 2013 | 06:11 PM
mitchk90's Avatar
Haha, sorry for the stupid question. Just making sure before I tear it apart. And I checked all the front end, and had a mechanic do it to on the lift just in case, and it all checked out.
Old Jun 4, 2013 | 06:15 PM
Sox-Fan's Avatar
Got Brakes?
It's not a stupid question if it's an honest one. Your mechanic should see wear patterns in the spring mounts which will clearly indicate a noise source.
Old Jun 5, 2013 | 03:31 PM
mitchk90's Avatar
Thanks for your help!
HEATON
Oct 16, 2015 07:21 PM
OrangeCoba
Oct 1, 2015 10:00 PM
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
