Coilovers causing shaking during acceleration.
Old Aug 4, 2013 | 11:54 PM
Supercharged JP's Avatar
I installed my stance coilovers last week and when i accelerate in any gear it has a horrible shake to it. Why is this? This also happened last year when i had HSD coilovers. I also have zzp stage 1 axles.
Old Aug 4, 2013 | 11:57 PM
Marca34's Avatar
How low are you? Are they maxed out? If so it's axle bind.
Old Aug 5, 2013 | 12:03 AM
It's not maxed out on the front but its close. How do you fix that?
Old Aug 5, 2013 | 12:14 AM
Marca34's Avatar
Rotated mounts.
Old Aug 5, 2013 | 12:18 AM
I have a ZZP engine mount, and front and back trany mounts.
drtibalt's Avatar
I have stock mounts and mine doesn't shake , im tuckin a bit in the front
Old Aug 5, 2013 | 12:25 AM
Marca34's Avatar
Wheel alignment maybe. Maybe hubs are going bad? Axles going bad?
Old Aug 5, 2013 | 12:28 AM
Never thought about the hubs. I will check though's and post again once i know.
Old Aug 5, 2013 | 12:30 AM
drtibalt's Avatar
hubs most likely
Old Aug 9, 2013 | 10:03 PM
kzak104's Avatar
probably axel bind if your not a sc or tc
Old Aug 9, 2013 | 10:07 PM
Sox-Fan's Avatar
Got Brakes?
are zzp mounts actually rotated?
Old Aug 10, 2013 | 05:18 PM
kzak104's Avatar
Yes
Old Aug 11, 2013 | 10:35 PM
Killa SS's Avatar
could be inner cv bearings. Just had to re build mine. Look in to it
Old Aug 11, 2013 | 10:43 PM
ls1fbody's Avatar
Haz l33t wheelz.
This is because you have a TC. The SC hates being lowered.
OP, it's axle bind. Raise the car back up and I guarantee it goes away.
Old Aug 11, 2013 | 10:49 PM
Powell Race Parts's Avatar
Originally Posted by kzak104
Yes
Nope/. check it out.
Old Aug 11, 2013 | 10:52 PM
The other thing that happens is that none of these coil overs ( stance and HSD who make Stance as a private label) have a bearing on the top hat/camber plate. They use a shim of steel or plastic. doesnt work.
It needs a torrington bearing. If you get one of those, while it will have a tough time standing up to dirt and grit and will be killed in winter driving salt conditions, it will certainly help make your coil overs nicer to dodge potholes manhole covers and speed bumps.
Old Aug 13, 2013 | 09:47 PM
kzak104's Avatar
yes they are, unless they are lying when they say rotated transmission mount
ZZPerformance - Rotated Rear Trans Mount #ZZ-RTMNT-REAR
Old Aug 13, 2013 | 09:54 PM
Read the threads posted by Matty O, here, or better still go buy a set, remove your old mounts and them put the zzp mounts in; let us know if they will install without moving the engine.
Old Aug 13, 2013 | 10:05 PM
kzak104's Avatar
i have them, im pretty sure i jacked the motor up to align the rear one.
Old Aug 13, 2013 | 10:16 PM
if you didnt drop the front and just raised the rear all you did was compress the heck out of the front and rear motor mount inserts
not rotated. take this discussion off line perhaps. its a non issue as far as i am concerned.
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
ernnyyes
Oct 2, 2015 05:16 PM
