KSport GT vs KSport Kontrol: What's the difference?
Old Oct 19, 2008 | 09:06 PM
JL-KA's Avatar
Hey,
What's the difference between the KSport GT & Kontrol Coilovers?
The GTs are more expensive so they must be better in some way...not sure how.
Only diff i see is the inverted design of the GTs...again not sure why that makes them better.
I'm new to coilovers so if someone could help me out that'd be great.
GT:
http://www.ksportusa.com/asp/coilove...roduct_id=cd02
Kontrol:
http://www.ksportusa.com/asp/coilove...roduct_id=cd01
Thanks,
Justin
Old Oct 20, 2008 | 07:45 PM
O2br2's Avatar
The inverted design places the body of the shock at the top instead of the bottom and that helps to reduce unsprung weight. Reducing unsprung weight helps makes the car a little more responsive especially in turn-in. If you install inverted coil overs with stock wheels and tires you probably won't notice any difference in how the car responds to steering input. If you combine that with some good light wheels and lighter tires you will notice that it responds to driver input faster. And reducing weight also helps acceleration but you really need to take off at least a hundred pounds or more to notice the difference in acceleration and inverted coil overs only reduce unsprung weight by a few pounds at each corner.
And unsprung weight is all of the weight of the car that is NOT supported by the coil springs. Like shocks, wheels, tires and brake rotors and calipers.
Old Oct 22, 2008 | 03:28 PM
JL-KA's Avatar
So...worth the extra few hundred or not?
Old Oct 22, 2008 | 03:30 PM
boostaddict's Avatar
^^only if you plan to buy lightweight wheels and tires
Old Oct 22, 2008 | 06:39 PM
TurboTechRacing's Avatar
Ksport is made in china BTW...
KW Suspensions is german made, same company that R&D's for the formula cars... Dont cheap out on coil overs, a year or two from now you will regret it...
Old Oct 23, 2008 | 01:37 PM
JL-KA's Avatar
Magnesium wheels are going on in the spring.
Old Oct 25, 2008 | 08:10 PM
thehov's Avatar
that there is some good advice!
Old Oct 25, 2008 | 08:20 PM
Maven's Avatar
What wheels you getting?
Old Oct 27, 2008 | 12:12 PM
JL-KA's Avatar
Raceline
http://www.racelinewheels.com/p-224-magnesium.aspx
Do you guys have an adjustable camber plate for the KWs or does it come with a pillow ball mount up front?
Does height adjustment on the KWs affect the amount of shock travel?
Any waranty?
Old Oct 27, 2008 | 12:46 PM
ilovecars's Avatar
isent it bad to run track wheels on the street?
Old Oct 27, 2008 | 01:22 PM
Maven's Avatar
What are you paying? I would investigate those wheels further if I were you, Ive got some issues with them that I posted in the Raceline thread for the TC.
Old Oct 29, 2008 | 02:29 PM
JL-KA's Avatar
Ya I saw your post...even if they aren't actually magnesium they're ridiculously light. They quoted me at $205ea. If I get them and they aren't actually in the 9lb range I'll call bullshit and send them back. Waranty would be a good thing to ask about though given the price.
Old Oct 29, 2008 | 07:19 PM
tru2nrtt777's Avatar
100% truth
Great advice.
Old Oct 29, 2008 | 07:48 PM
Maven's Avatar
I am very interested to find out some hard facts on these wheels, Id love if they were 9lbs in 17" or even 16" but I just dont see that being even remotely close to the truth.
Old Nov 6, 2008 | 03:37 PM
JL-KA's Avatar
This seems to be a common belief. What do you guys think of the B&G coilovers sold by Gravana which are also European made versus the KWs?
Yeah I'll be looking into them in the spring when they actually start production. Honestly anything under 15lbs for a 17" wheel would be phenominal. I just don't really want to pay 400 a wheel.
turbochargedss2012
Sep 20, 2023 12:17 PM
biniecki
Oct 25, 2015 02:23 PM
Oct 13, 2015 09:32 PM
importkiller
Sep 30, 2015 07:18 PM
Sep 28, 2015 12:51 PM
