Moog End links
Old Oct 16, 2012 | 12:36 PM
user 72239's Avatar
Moog End links
Little back story, installed lower springs about 4 months ago. one of my stock end link bolts was not on all the way and fell off. well i drove for awhile like this and couldn't understand why it was pulling hard to one side. Went to do an oil change and I found out the bolt was missing. Replaced both of them with Moog End links.
Fast forward to today, my car seems to clunk really bad turning either left or right and I feel like my steering wheel column is clunking too. I checked the end links this weekend and they are attached and bolted good. Do I need to grease them? dont they come pre-greased?
Also, how difficult is it to tighten up my steering column
Old Oct 16, 2012 | 12:48 PM
Vander Nars's Avatar
this wont be of any help but about 3 weeks ago I did a full ss/tc fe5 swap with moog end links and pedders and i didnt have any kinda clunking so I have no idea other then check every bolt to ensure its tight. also i think they are pre-greased but I had my friend fill them all the way up at his shop took less then 5 mins so maybe have someone fill them up.
Old Oct 16, 2012 | 12:53 PM
Staged07SS's Avatar
Administrator
Administrator
I had a clunking when my endlinks went bad....
I replaced them with Moogs, and have been good sense.
Although, I had some clunking like you are describing on my initial test drive, and found it to be a loose bolt. Re-torqued everything, and I was good to go.
Old Oct 16, 2012 | 03:42 PM
user 72239's Avatar
ok, maybe thats what ill do. I didnt take the wheel off just inspected it. Thanks
Old Oct 16, 2012 | 05:12 PM
07cobaltLScoupe's Avatar
i make sure mine get fresh grease when i swap my summer/winter wheels out, so twice a year. been on for probably 2 years and have no clunking, even now with coilovers. i just keep everything greased up and it's all fine
Old Oct 16, 2012 | 05:14 PM
CobaltItaliano's Avatar
make sure they're fully greased and re-torque all the bolts you loosened in the install.
Old Oct 16, 2012 | 05:30 PM
Gelladuga69's Avatar
Noob question.. How/why do you grease these? I had these put on last year when I was getting other work done at a shop, because it was winter.
Old Oct 16, 2012 | 06:20 PM
^ get a grease gun and fill the greasable nipples sticking out of the links
Old Oct 16, 2012 | 06:36 PM
Awesome thanks.
Old Oct 16, 2012 | 06:42 PM
Wangspeed's Avatar
Step 0. Clean the zerk fittings with brake cleaner FIRST. It is a sure fire way to destroy a ball joint by injecting grease when the zerk fitting is dirty.
Quite honestly, I prefer sealed ball joints over ones with zerk fittings.
Old Oct 16, 2012 | 08:16 PM
How often do you have to inject grease?
Old Oct 16, 2012 | 08:20 PM
I put moogs on last winter, havnt touched them since lol. I probably should this year.....
Thanks wangspeed, I would have never thought to do that first
Old Oct 16, 2012 | 10:19 PM
this. thanks for adding that
turbochargedss2012
Sep 20, 2023 12:17 PM
Solaris99
28
Mar 15, 2017 01:22 PM
patooyee
Oct 15, 2015 05:11 PM
OrangeCoba
Oct 1, 2015 10:00 PM
ThoR294
Sep 28, 2015 05:31 PM
