need camber adjustment or new camber and possibly shim.
Old Mar 6, 2008 | 01:25 AM
aircrew85's Avatar
my 2006 chevy cobalt lt 2.2 needs the camber either adjusted or a new camber and possibly shim on the back passenger tire.the tire does not sit level on the ground and the inside of the tire wears faster than the rest.putting it up against laser measures shows its off 1.85 degrees.can i adjust this myself.the top of the tire sits in towards the car and the bottom of the tire sits out from the car, where the 1.85 degrees comes into play.if i can adjust this myself that would be awesome.any help on this would be greatly appreciated.
Old Mar 6, 2008 | 01:41 AM
timmyhoes's Avatar
not really but theres a sticky if you search "alignment". Are your stuts f*& or did you install lowering springs? cuz that will affect your camber.
Old Mar 6, 2008 | 02:16 AM
aircrew85's Avatar
dont think my struts are messed up.dont know for certain though.and there are no lowering springs on it...not until i get this issue resolved.
ok..found my paper with the specs on it.things seem to be ok except the rear passenger tire as i stated above.it says the camber is -2.1 degrees and the Toe is -1.85 degrees. what can i do about this myself?? i know i need an alignment done but is there anything i can do before that???
Old Mar 6, 2008 | 04:30 AM
jperris's Avatar
did you mash it into a curb or something? for a rear wheel to be so out of whack, something has to be bent.
Old Mar 6, 2008 | 04:35 AM
REIGN SS's Avatar
Original Hayden Fanatic
Moved to Suspension
RaginChopsuey
Oct 27, 2015 01:27 PM
patooyee
Oct 15, 2015 05:11 PM
justinchinn
Oct 2, 2015 12:18 PM
Tupp
Sep 30, 2015 08:18 PM
OPCrer
Sep 27, 2015 08:11 PM
