should this happen after i install sportlines?
my steering wheel sits about 15 degrees to the right ... i havent got an alignment but i have an appointment on mendsaday .. will it be fixed after that?
p.s. who ever started the rumor of needing a spring compressor to take apart the front struts ... is WRONG ...
A proper wheel alignment should straighten the wheel.
Do you NEED a spring compressor? Maybe, maybe not. Will it make the job easier? yes. Will it help prevent injury? yes.
thanks buddy. and i just took the strut out ... took the top off and it just popped off .. very little pressure ... but yes ... installation would have been easier with them
thanks again
thanks again
No that's not normal, though an alignment will fix that. I can't believe you changed the alignment that much with just a spring change, you must have messed with way more than you needed to.
tell yourself that we'll wait for your pics with one eye and no teeth
Yeah DEF not normal I just installed mine last weekend and have had no problems with it pulling or anything..(WTF did you do?! )
but I'm still going to get an alignment after spring break.
and you had to have compressors to get the new springs on the strut...?
there isnt any pull or anything ... just a little camber ... and the alignment is off ... it was off a little before i did it tho ... there isnt too much u can do wrong .. its only 2 bolts and a sway bar link ...
and i did it fine with no compressor ... just took it apart and when i put it together ... i pushed down on the top while my buddy screwed the stru top back together ..
agentirons
Oct 16, 2015 02:11 AM
